Old 01-19-2014, 10:03 AM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
Default Replacement Flywheel
Anyone know how I can find the part numbers for a different flywheel for my engine? I have a YIO-540-D3A5 (standard Vans setup). But it came with a dual groove flywheel and there are no boss mounts inside the flywheel. The lack of those mounts make it impossible to use a Plasma type Electronic ignition. So I want to research what it would cost to get another flywheel but not sure where to look.
The Lycoming parts catalog just shows the flywheel as part 72566 but doesn't list any options on single/dual groove or boss mounts.
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 01-20-2014, 06:18 AM
bill@fusion4.net's Avatar
bill@fusion4.net bill@fusion4.net is offline
Default PN LW-16471 SUPPORT ASSY-STARTER RING
is the single belt flywheel with mounting holes.
There are a couple available on e-bay, both new and used.
I just got mine exchanged from Lycoming. I had asked for
the single one when purchasing the engine, and they would not
change the factory production, but said the would swap it once I got the engine.
15 months later I finally hung the engine, and they swapped it out. I was afraid after that long that they would not, as all I had was a phone conversation, but called them up, and once I got the experimental department they said no problem and sent me the new one the next day.
Bill Thomasson
RV-10 - Flying - Phase II. 99.8% done... it's never really done!
http://sites.google.com/a/fusion4.net/rv10/
Suwanee, GA.
Old 01-20-2014, 06:28 AM
Scott Hersha Scott Hersha is offline
Did you check with Klaus? I think he will sell you one and he'll install the magnet ring properly for you.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
Old 01-20-2014, 08:46 AM
bpattonsoa bpattonsoa is offline
I ordered my YIO -540 from Vans and then requested (Ann) that it include the single belt flywheel. No issue, that was what it came with.
Bruce Patton
Rans S-20 Raven 796S flying since 2019 (slowly)
RV-6A 596S flying since '99 (Sold)
HP-18 5596S flying since '89
RV-10 996S flying since 2014, quick build wing and slow build fues., - dual Skyviews with complete system, two radio and not much else. Interior completely finished with Zolatone. CF plenum. 1624 lbs, FLYING after a 21.5 month build.
