01-15-2014, 04:09 PM
Workbench height?
I have not had luck searching this question.
How high should I build the work table? The chapter 100 plans call for 33 3/4", others have said elbow height. What has been your height experience?
Barney Johnson
14A #140111
started build 12/24/13
Empennage done, wings done, fuselage done, finish kit in progress.
Dormant 2017, 2018,2019
Back at it 3/20
01-15-2014, 04:12 PM
I am building a 14. I built the standard height bench as you described. I wound up building some removable leg extentions that raise the top 8 inches for some of the work. Were I to do it again, I would also design it to be 6 inches lower at times.
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 500+
2020 Dues Paid
The Dues Paid note is a reminder for me
01-15-2014, 04:18 PM
It's useful to have several work areas available. I'm 6'1" and my workshop has a 2'x8' bench @44", a 2'x8' bench @ 40" and a movable 3'x6' @ 36".
Gary
RV-6, First flown 1995
Another RV project under VERY serious consideration
01-15-2014, 05:35 PM
bench height
I built three the height you mention. Two were the EAA plan. There was leftover plywood so I built a third using the leftover and the same concept and height. The third is for all the electric bench tools and the vice. They get used every day and a lot of though went into where tools were mounted.
The two EAA benches are exactly the same so they can go end to end or beside each other for a consistent flat surface. I drilled them for several tools and jigs such as the bending brake and leading edge rolling j bolts.
I think it comes down to comfort. I'm short at 5'6" and they work great for me. I don't have to bend over or squat to work. A rolling chair is perfect to work on stuff on the bench while seated. With my busted leg, I've been using the chair quite a bit.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
01-15-2014, 05:44 PM
37" works for me. Like you, I studied the matter before building my bench. Elbow height is a good reference. I'm 5'9". To me, nothing is worse than working while having to bend forward just slightly. It's a back killer.
John Halcrow
Tustin, CA
RV-12 120682
Emp/TC done; Wings done; Fuse kit done
"History teaches us that men and nations behave wisely once they have exhausted all other alternatives." --Abba Eban
Paid up until Aug 2021
01-15-2014, 06:01 PM
I'm 6' tall and built all my tops (3) the same height so I could put them together if I wanted. 36" feels about right for me but thats just me. I also put everything on wheels. Also makes it easy to roll them outside and clean the workspace with a blower.
Paul K
West Michigan
2020 donation made, exempt but worth every dime!
01-15-2014, 06:11 PM
36" here, too - on lockable casters.
01-15-2014, 07:01 PM
I'm 6'0" and for years have been building my work benches and work tables 38" high. That's the perfect working height for me ... way more ergonomic (for me) than the standard 36'.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
01-15-2014, 07:38 PM
I'm 5' 8" and have two at 36" and one at 34.5". The lower one is too low.
I used to have one at 38" and it was too high.
Dave
01-15-2014, 07:48 PM
Senior Curmudgeon
AMEN
Much rather have a bench that is an inch too high, than one that is an inch too low.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
