Go Back   VAF Forums > The Never Ending Debate Section > Tools
View Poll Results: Where Did You Buy Your Big Compressor?
Home Depot Aviation Supply 31 33.33%
Lowes Aeroplane Supply 16 17.20%
Tractor Supply (Aviation department) 3 3.23%
Sears Aviation Wholesale 9 9.68%
Harbour Freight Seaplane Division 7 7.53%
Custom made by Swiss Watch Makers with help from German engineers 3 3.23%
Other - post good deals! 24 25.81%
Voters: 93. You may not vote on this poll
Old 01-15-2014, 12:12 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Default Where Did You Buy Your 60 Gallon Compressor?
Now that Louise and I are settling into the new, permanent home in Nevada, it's time to discard the sorely-worn portable compressor and install something permanent. I am thinking 60 Gallon vertical tank - we hate running out of air when both of us are using die grinders.
Of course, all of the usual suspects sell big machines - Home Depot, Lowes, Harbour Frieght...just curious where folks have bought their big compressors - and of course, how happy you are with the choice. Poll choices reflect what is available in the Reno/Carson area (sort of )
(I must say that I only go to HF for things I am going to use once, modify, or plan to destroy quickly - but who knows...maybe they do OK with big chunks of iron?)
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 01-15-2014, 12:24 PM
Mel's Avatar
Mel Mel is offline
Default Not quite Swiss or German, but it's 80 gallons and?...
A local compressor shop here is Dallas built it up for me in 1989.
It is used every day and hasn't missed a beat. Drain daily and change oil annually.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 01-15-2014, 12:25 PM
RV8iator's Avatar
RV8iator RV8iator is offline
I've had my HD Aerosupply compressor for 13 years now and going strong. You just can't have too much volume..
Jerry "Widget" Morris
RV 8, N8JL, 3,000+ hours on my 8.
VAF #818
Saint Simons Island, GA. KSSI
PIF 2008, 2009, 2010, 2011,2012, 2013, 2014, 2015, 2016, 2017, 2018, 2019, 2020
I just wish I could afford to live the way I do
Old 01-15-2014, 01:05 PM
Sid Lambert Sid Lambert is offline
Tractor Supply had a nice sale on compressors after Xmas. Not sure if it's still going but they had a good price on a stand up IR.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
Old 01-15-2014, 01:31 PM
Guy Prevost's Avatar
Guy Prevost Guy Prevost is offline
My wife bought a Craftsman Industrial unit for me. It's a 135psi parallel twin job. The pump failed part way through the build, despite annual oil changes and general good care. I replaced the pump and the motor and tank have been fine.
A websearch indicated that I was not alone with this problem. Nobody ever reports good news, so it's impossible to quantify whether or not there is a real quality problem. I may have just had bad luck, but it soured me on the compressor somewhat.
Guy Prevost
Albuquerque, NM
RV-8a Built, Enjoyed, Sold
Two Kids: Built, Enjoying
RV-10, Bought, Rebuilt, Enjoying
Build / First Flight Video: http://www.youtube.com/watch?v=8f9HXzZT1dE
Build Log: http://websites.expercraft.com/geprevo/
Arguing on the internet is like having a competition to see who can hit a brick wall the hardest. You may win, but you're still an idiot.
Old 01-15-2014, 01:32 PM
scard's Avatar
scard scard is offline
Whatever you do, don't buy an IR model SS5. They have a defective head gasket that leaks between the cylinders.
Scott Card
CMW E-Lift
Old 01-15-2014, 01:35 PM
I had a large one from Lowes and it crapped out in less than a year. I got one from HD, and it has lasted about 2 years so far and looking good. I use it for woodworking too, so it gets work.
I wouldn't rule out HF. I bought (3) 3" trash pumps and have used them daily for the past 3 summers pumping sprinklers 6 hours a day without missing a beat. I had a Honda pump - cost double what the 3 others cost total and it died after 1/2 season.
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
mburch's Avatar
mburch mburch is offline
Hey Paul, I went straight to the source and bought a factory zero-timed 60 gallon upright unit from Campbell Hausfeld. It says "Husky" on the label, which is the Home Depot store brand, but it was a lot cheaper than Home Depot's asking price!
I may have to check out the Swiss horologist / German engineer idea next time around though...
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 01-15-2014, 01:46 PM
Interesting! I wonder if they make the Craftsman I have. Same failure mode I had and the pump appears to be identical.
Guy
Guy Prevost
Albuquerque, NM
Old 01-15-2014, 01:51 PM
rleffler's Avatar
rleffler rleffler is offline
The poll didn't allow multiple choices.
My first compressor was a large Husky (Campbell Hausfeld) 80gal, 240v that I had in the garage for the first years of my build.
When I moved to the airport, I couldn't get 240v in the hangar, so I went cheap thinking I didn't have much riveting work left. I bought a 30 gal, 120v Harbor Freight special. It lasted about six months, so it wasn't covered by warranty.
I then purchased a more expensive Husky, 120v unit. It too died within a few months. Fortunately, it was covered under warranty. It took the local repair shop about three weeks to fix.
During this down time, I discovered that there was a common known failure of the HF compressors. Basically the gasket failed. At this point, what did I have to lose. I can build an airplane, I should be able to fix the compressor. I bought some gasket material from the local auto store and replaced the gasket.
So now I have three working compressors, but only using one at the moment. I moved during this process and don't have a 240v source for the good compressor at the moment. But in time, I can solve that problem. I'm having more fun flying and completing Phase I than to do projects at home.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
