Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 01-14-2014, 03:30 PM
jnmarshall jnmarshall is offline
Default Apollo GX55 System Initialization Screen
Does anyone happen to have the installation manual for the GX55? Apparently it's different from the GX50/60/65. I have a need to get to the test menu to perform a system initialization and the users manual doesn't cover that. I'm hoping it's the same as the other models where you hold the left and right soft keys while switching the unit on.
Old 01-14-2014, 04:58 PM
plehrke's Avatar
plehrke plehrke is offline
I have the user guide for the GX series which has the 50, 55, 60, 65 in it.
Philip
RV-6A - 14+ years, 900+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 01-14-2014, 05:54 PM
I have the user guide. Looking for the installation guide.
Old 01-14-2014, 06:19 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
I have a GX50/60/65 installation manual, and I believe the GX-55 is essentially a GX-50 that was made plug-in compatible with the older Apollo Loran units.
I can't send it to you because you have not enabled e-mail on VAF...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-14-2014, 07:04 PM
I have the same manual. I'm trying to confirm functionality is the same for the test modes even though the connections might be different. I couldn't find the installation manual and google searches didn't find one either.
Old 01-14-2014, 11:20 PM
az_gila's Avatar
Question
Which test modes?
I'll go and fire up the GX-55R in my Tiger and check.
BETTER STILL
Thanks to the Wayback Machine, Garmin's (well Apollo's actually) original GX-55 Installation Manual was captured a decade ago -
https://web.archive.org/web/20040608...stallation.pdf
Gil Alexander
Old 01-15-2014, 07:52 AM
Which test modes?
BETTER STILL
Exactly what I needed. Looking for the ones on page 15. Thank you so much!
