03-25-2019, 07:18 PM
In case anyone is getting tips from this thread in 2019, the Crow harnesses have evidently have changed a bit. It looks like older Crow crotch strap attach brackets were somewhat thicker than the 1/8" spacing that Vans calls out in their crotch strap kit, so I built mine 1/4" apart to be safe. And the mounting hole was bigger, causing builders to look for bushings to make them fit. Well, just got my Crows and lo and behold their attach brackets are 1/8" thick and the attach holes fit the AN5 bolt perfectly. Drop-in replacement now! Too bad I went through the trouble of adding extra space between the brackets. Looks like I'll be adding a couple of washers to ensure a tight fit.
Ryan Drake
Livermore, CA
https://stiletto.smugmug.com/RV7
Donated 12/16/2019
RV-7A (N12VD): Empennage and wing kits complete minus fiberglass, fuselage and wiring complete. Canopy complete minus fiberglass. Waiting for the engine to come!
04-24-2019, 08:45 AM
I did a fairly in-depth out of the box review on the 2018/2019 crow harnesses noting that they have changed the mounting pieces and the cam lock hardware from older models.
http://www.vansairforce.com/communit...d.php?t=167112
04-24-2019, 02:03 PM
Ryan,
It's been a while, but I think I allowed extra thickness for the crotch strap too. I'd be interested in taking a look at your belts. What color and options did you get? I think I want the all black hardware but I was a little confused about some of the other options.
Ray
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
04-26-2019, 12:11 PM
I got the same ones Garet reviewed (above): KAM LOCK RV6/RV7/RV9/RV14 AIRCRAFT RESTRAINT WITH PADS is the part name on Crow?s site. I?ll be back in town after May 8, happy to bring them by your hangar one day.
Ryan Drake
Livermore, CA
Donated 12/16/2019
05-26-2019, 06:13 AM
I recently bought my flying -7 it has I assume the Van?s 4 point system in it. Can the bracket hardware for the crotch be added?
05-26-2019, 11:29 AM
I would think you could. The forward seat floor pieces can be removed to get access to that area. Some people put their comm antennae in that area so if the crotch mount isn?t there now that may be something to check out first.
Ray Tonks
2020 Donation Paid
RV-7 SB Wings
* Ailerons Complete
* Flaps Complete
RV-7 Preview Plans
05-26-2019, 01:31 PM
Recommend it
I was copilot in a friend?s RV9A. Didn?t have crotch belt attached as we were Flying in smooth air. We hit some unanticipated rough air. My head hit the canopy fairly hard. Connected the crotch strap right away. Ever since I always connect my crotch strap. The thought of becoming incapacitated while flying is not very appealing.
Keith
RV 7A RV #9700 May 2017
N325KS the Flying “K”
Built in SoCal KCCB, now in GA @ KPXE
550+ Hours & 7X cross the USA
OSH flyin 2018 & 2019 & Petit Jean 2019
05-26-2019, 05:36 PM
Originally Posted by jy757
I recently bought my flying -7 it has I assume the Van’s 4 point system in it. Can the bracket hardware for the crotch be added?
I added the RV7 5th point attach hardware to my RV6A no problem after RV6A already flying. Be careful when drilling through bracket flanges to ribs as bracket flanges are pretty soft and right angle drill bit can wander and enlarge hole if not careful. I also clecoed some 1/8 in. Thick Strips between front and rear brackets to maintain the proper spacing and alignment while drilling bracket flanges to ribs, which really helped. It also helped in drilling hole through both brackets for AN5 bolt with bracket not installed.
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2020 Donation sent.
N53KT RV-6a finished 2018, Flying
N7053L RV-4 Wife's RV
N56KT RV-4 Finishing
05-26-2019, 08:03 PM
Thanks for the info...
05-28-2019, 07:38 PM
Thanks, I will check that out before going any further...
