01-12-2014, 10:32 AM
PMA 5000EX Iphone Input Cable Help
I am interested in using the cell phone input function on the PS engineering PMA 5000ex audio panel. Would anyone know which cable I need to buy to make this possible. PS Engineering only lists a P/N and wants $40+ and I know I can get it online for $5,if I know what is needed.
Hopefully someone can point me in the right direction.
Cam
01-12-2014, 11:01 AM
Tip, Ring, Sleeve
Any TRS cable should work... You don't need a 4th conductor.
http://www.amazon.com/s/?ie=UTF8&key...l_2nacqk2nzt_e
$6 and you're good to go.....
John Walker
RV-10 N265WD
"Miss Whiskey Delta"
BPE IO-540, FULL EFII
KMYF, San Diego, Ca.
KEOS, Neosho, MO
Crew Chief
Grove Aero Super Legacy Reno Racer,
twin turbo, IO-540,
full EFII management system!
Race Coordinator STOL Drag coming to Reno, 2019
"so I got that going for me... which is nice."
01-12-2014, 11:03 AM
Check your local Radio Shack or search on "iphone audio cable 3.5 2.5". It's 3.5mm on the audio panel and 2.5mm on the phone.
Try http://www.aliexpress.com/item/RC-00...697419477.html
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
01-12-2014, 11:52 AM
PMA 5000
Hey Cam,
I'm also going with a PMA5000, what are you hooking up to it?
Don
01-14-2014, 05:02 AM
Originally Posted by Don Patrick
Hey Cam,
Don
Don,
I purchased this cable off Amazon. I am hooking up an Iphone 5 to make calls when on the ground. You do in fact need a 4 conductor cable to be able to use the in/out of the phone.
http://www.amazon.com/YCS-Basics-foo...le+4+conductor
Cheap and works great.
Cam
01-23-2014, 08:27 PM
Other avionics
Sorry, I should have been more specific. What radio are you hooking the PMA 5000 up to? I'm have an SL40 that I will hook up with it and was just looking for anyone that may have the same setup.
Don
01-24-2014, 05:21 AM
Cable
Hi Cam, can you please confirm that this cable is working for your iPhone5 and the PMA5000EX?
I'm concerned that your mic on the headset will not connect. If the party on the end of the call says they can barely hear you, that's because the audio being picked up is from the mic on the phone.
If it doesn't work, we have literally reversed engineered the circuit in the iPhone and altered the 4 circuit connector which tells the iPhone to turn off the phone's mic and allow external mic audio to be used.
But if the cable works, we will spread the word on our web site, we are not in the biz to build patch cords! It was more of a service, I promise!
Mark Scheuer
PS Engineering
Originally Posted by Cabbott14
Don,
Cam
Mark Scheuer
PS Engineering, Inc.
VAF Advertiser
01-24-2014, 11:43 AM
Don
I have an SL40 and the PMA 5000EX. SteinAir did the wiring. I ordered a 'regular' 2.5male to 3.5 male cable and it did not work with the Iphone 5. Ordered a 4 conductor and it works great.
Volumes of G3X alerts, volume from radio comms and everything else seems 5/5.
Not sure if it had something to do with the volume through one of the different components, but I could not hear them and they could not hear me at all the settings we tried.
Hope this helps. I'm away from the plane for a while, but can have my it checked out further if needed.
Cam
01-24-2014, 11:49 AM
Mark Scheuer
PS Engineering
Mark,
Now to think of it, we only operated the phone and new cord on the ground briefly and they very well could have been hearing through the mic of the Iphone 5 and not the mic on the headsets.
I didn't even think to cover the Mic of the phone up or anything, it was just sitting on the dash.
I will look into it.
Cam
