01-12-2014, 08:13 AM
G3X Keep Alive
I've spent 90 minutes pouring over the install manual and can not find the keep alive circuit for the G3X system. Can someone please help with a connector number or section of the manual and put out me out of my misery?
thank you
Bob Markert
Littleton, CO KBJC
Reserve Grand Champion Oshkosh 2016
Renegade Opposing Solo pilot and other Dirty Odd Jobs
http://www.rmrairshows.com/
2019 dues paid
01-12-2014, 08:41 AM
The G3X does not have a "keep alive" power input.
01-12-2014, 09:04 AM
thank you
Hello Bob,
Could you explain what you mean by a "keep alive circuit".
As you likely know, most of the G3X components have dual power inputs which can be used for primary and backup power inputs.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
01-12-2014, 11:23 AM
Keep alive
By Keep Alive I mean a wire that goes to the hot battery buss to maintain memory items such as the clock and data logs . Some systems need this trickle current to save data when the aircraft is shut off.
Bob Markert
Littleton, CO KBJC
2019 dues paid
01-12-2014, 11:33 AM
Hello Bob,
This is not available or needed on a G3X system.
When you shut down your G3X system you will remove all power and there will be zero current draw on your aircraft battery.
Steve
Garmin G3X Support
g3xpert@garmin.com
01-12-2014, 01:07 PM
Steve
I guess that makes me "green energy compliant" .... Until I fire up the 205 hp IO-375
Thanks for the quick reply.... Again
Bob
Bob Markert
Littleton, CO KBJC
2019 dues paid
