Old 09-11-2006, 11:17 AM
rv9builder rv9builder is offline
Default Flox between layers of glass cloth
The Aircraft Spruce catalog says "NEVER use micro between glass layers." Is it acceptable to use flox or some other type of filler between glass layers?
Thank you,
Mark
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2020
Old 09-11-2006, 11:58 AM
mdredmond mdredmond is offline
How much build-up do you need?
You should alternate layers of cloth and mat. A bunch of mat or chopped or milled glass can be used as a structural filler. Not sure if you can use flox between layers of cloth, but seems to me it would not be nearly as strong as mat or chopped glass.
Matt Redmond
Denton, TX (KDTO) - VAF #510
Got the Bug & Wife's Signoff
RV-9 Tip-Up, Empennage & Wing
Old 09-11-2006, 11:59 AM
gpiney gpiney is offline
Thank you,
The basic answer is NO! The strength of multiple layers of fiberglass comes from them being together with no voids or other material between them. A composite sandwich (glass-foam-glass) can also be made very strong.
Flox mixture is Very Heavy. Sorta defeats the purpose. Flox is generally used where a hard surface or point is needed.
If you could describe your problem, a better solution may be given.
Greg Piney
RV-8 2547
Empennage Done!
Beginning Fuselage Final Assembly!
(Tub finished, on to Landing Gear).
Old 09-11-2006, 01:07 PM
f1rocket's Avatar
f1rocket f1rocket is offline
Thank you,
You should never use micro between layers, but flox is sometimes acceptable. There are usually other techniques that are stronger and lighter than flox to build up an area that should be explored first. Describe your problem in more detail and pehaps we can assist you with a solution.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 09-11-2006, 01:24 PM
Thank you,
Having been somewhat educated in the EZ world, the answer is NO.
I do not recall ever using a filler between layers of glass.
dd
Old 09-11-2006, 02:46 PM
Finley Atherton Finley Atherton is offline
The only time that flox is "sort of" used between glass layers that I am aware of is when two lay-ups of glass meet to form a corner over a foam core. In this situation the corner of the foam is removed after one of the sides has been layed-up and allowed to cure. The resulting void is filled with flox and the other side is then glassed over the wet flox. So you end up with two glass lay-ups joined by flox at the corner.
Fin
9A Australia
Old 09-11-2006, 02:57 PM
Thanks for everyone's help. I'm working on a fiberglass rear skirt for my 9A slider. There is one area where I think I can get a smoother shape if I add some filler. I was going to add some filler, and then do another glass layup over the original layups and the filler. Based on what you guys are telling me, it sounds like I should do all of my glass layups first, and then put the filler on top, instead of sandwiching filler between the different layers of glass.
Mark
RV-12iS Fuselage
RV-9A Project: Sold
Old 09-11-2006, 03:10 PM
You got it.
Greg Piney
RV-8 2547
Empennage Done!
Old 09-11-2006, 03:17 PM
f1rocket's Avatar
Fin
9A Australia
That's the primary one, but if you lay a bunch of plies to make a hard point, and you need to smooth the transition around the build-up, you can lay in some flox in order to avoid any voids in the layup. Generally, the use of flox between layers is avoided because of weight, not strength. It is extremely hard and strong, as you probably know, but weighs quite a bit. Glass cloth with grab flox quite readily and not let go. Not so with with micro, which will stick to the cloth, but has a very, very low shear value and the glass will easily seperate from the micro with just a minimal shear load.
Randy Pflanzer
Greenwood, IN
Paid through 2043!
Old 09-11-2006, 04:55 PM
DanH's Avatar
DanH DanH is offline
He's talking about a canopy skirt, not a structural part. No problem with flox core between cloth layers in that application.
Dan Horton
