Old 01-10-2014, 12:44 PM
Michael Burbidge Michael Burbidge is offline
Default Countersinking longerons for empennage gap fairing...
Countersinking the longerons made me nervous when I did it for the rivets that attach the fuselage skins. But it really makes me nervous countersinking for the empennage gap fairing, which attaches using #6 screws.
You have to create a pretty deep countersink for the fairing to sit flat.
Here's a couple of pictures. You can see that my fairing still doesn't lay flat against the longeron. Should I go further with the countersink? Is there concern about weakening the longeron if I go further?
Michael-
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
Old 01-10-2014, 07:59 PM
rvbuilder2002's Avatar
Michael-
The photos make it hard to tell for sure, but I think at least part of the problem is that the dimples for the screws are not fully formed/flat. Use a c frame tool to give them a good whack and check again. Then if they still don't lay flat, countersink a little deeper. All of the Van's demonstrators are done this way (that's why the manual says to do so).
Scott McDaniels
Hubbard, Oregon
Old 01-11-2014, 12:56 AM
PIN 37 PIN 37 is offline
What am I looking at in the top photo? it appears that there is a rivit head overhanging an edge, That cant be right surely??
Phil
LAME (Aust)
RV7 99% finished
Old 01-11-2014, 02:10 AM
WAM120RV WAM120RV is offline
Default Photos
Michael
Can you put some better photos up.
The top photo appears to show rivets that would not have enough edge clearance on the longerons underneath the cover plate. 2d is required.
Then the bottom seem to show over dimpled holes..
But there is probably nothing wrong we need better photos to work from.
http://www.aerobuilder.blogspot.com
Steve Arnold
England
In completion stage of Loehle P5151
Built and now Flying G.BVLR Vans RV4
Rebuilt G.BDBD Tailwind
Rebuilt G BVTN Kitfox
Built G CDCD RV9A with WAM120
Riveted wings on Glastar G.LEZZ Now (G. SKUA)
Old 01-11-2014, 06:25 AM
Walt's Avatar
Walt Walt is offline
I just riveted my gap fairings on and sealed the gap with a nice bead of proseal, I did not see any need to make these removable.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 01-11-2014, 07:04 AM
Jesse's Avatar
Jesse Jesse is offline
That makes a lot of sense. There really is no need to remove these. The only reason I could see that they were made removable is to replace the rubber channel when it falls off.
Jesse Saint
Old 01-11-2014, 09:03 AM
bret's Avatar
bret bret is offline
Zoom in, you are looking at a bicycle tire at the bottom of the rivet
