Old 01-10-2014, 10:16 AM
brad walton brad walton is offline
Ok. First determine there is a leak and then start looking for it. Soapy water works well for that. When I tested mine with the manometer method, I detected leak down and found the only leaks were at connections and the gas cap. Covered the gas cap with duct tape and still found very small leak at an overlap of the tape. But once these miniscule leaks were corrected, my manometer rose and fell with temperature and barometric pressure.
Old 01-10-2014, 06:53 PM
Robert Anglin Robert Anglin is offline
Default Sorry.
Mr. Walton is on the right track and yes the balloon is to keep you from over doing a pressure level in the tank as it does not take more than 4-6 p.s.i.g. for one to bust a seam wide open. Sorry I did not mention the old soap trick before, it should be part of the testing of a tank. Only one comment the little bottles of soap you get down at Lows or in some hardware store aviation department, that are used to test for gas leaks on a home hot water heater.
These seam to work the best of any we have run across as the stuff bubbles up to show a leak better than any other soap we have found to date.
If it hold good pressure for a couple of days and you don't find any soap bubbles then fill it with mow-gas and let it set for a couple of days. You may still see a small wet spot. If you need to then you can drain the fuel and put it in your road mobile tell you fix that wet spot. "Don't ask the answer is yes" hope this helps Yours as always R.E.A. III #80888
Old 01-12-2014, 07:55 PM
Mark Jackson Mark Jackson is offline
Default Damaging the tanks
I ended up using 1/2 tubing to construct a manometer. It worked as advertised and I found a couple pinhole leaks in the corner seals.
Thanks very much for all the replies, like drinking from a firehose.
Mark Jackson
Houston, TX
RV-8 in progress/Mooney in the hangar.
Old 01-13-2014, 05:49 PM
Default Trek or Canondal?
Houston, an inverted fuel tank and a good road bike tire pump.
How could we not? Yours as always R.E.A. III # 80888
