Old 01-08-2014, 03:45 PM
ppilotmike's Avatar
Default Capacitance Sender Hookup
With regard to the Vans cap senders, the bulkhead connection is a male BNC. I understand that a female BNC attaches there, but the wire going to the converter is probably NOT coax, right? I thought the BNC connectors are made for coax only... Can anyone please tell me how the cap senders get wired up, or better yet, show me pictures of theirs? Thanks.
Mike Rettig
VAF Dues Current
Old 01-08-2014, 04:44 PM
RV7A Flyer's Avatar
What converters are you going to use? Dynon sells some that have a female BNC on a small board, and the power/ground/signal wires coming out of that. I used it and wasn't happy with it due to the very small range of output voltages, which gave poor readings for fuel levels from around 12 gallons on down, so I switched to Princeton Electronics. Those have a long coax (not RG-400, don't know what it is) which terminates in a ring terminal, which then get's screwed onto a female BNC with a screw on the top. That wire goes to a box which can be mounted inside or wherever, and the power/ground/signal wires come out of that box. Advantage to Princeton: you can set empty, and it calibrates that to 0V, full gets calibrated to 5V, and then you go through whatever EFIS calibration procedure you need, and it gets the full 0-5V range input.
Old 01-08-2014, 04:47 PM
bird's Avatar
bird bird is offline
Default Sure
I used a dynon cap converter, it. Has a Bnc directly on the circuit board. It connects right onto the bnc on the tank. Others have the converter located remotely, those would get a single wire connected to center pin of bnc and connected that way, and the power and signal wire run from the converter to your system.
Bird
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for"
http://www.mykitlog.com/tcb328/
Old 01-09-2014, 10:59 AM
ppilotmike's Avatar
Default Thanks.
I appreciate your responses..
Mike Rettig
VAF Dues Current
