Old 01-06-2014, 02:47 PM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
Question difference between Lycoming cases
Does anyone know the difference between the following two Lycoming cases: LW-18379 and LW-18372
They are both used on various low compression wide deck O-320s.
The LW-18372 is listed on the high compression (160 HP) wide deck O-320s.
I'm looking to learn the actual difference between the cases - is the 18372 stronger in some area? Do they use the same bolts / studs / hardware, etc?
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
Old 01-06-2014, 03:08 PM
Sid Lambert Sid Lambert is offline
Once it's been in for overhaul they can change just about any aspect of the case. My old thin bearing E2D is now a thick bearing A1A drilled for constant speed.
They even said they could convert it to a 360 case.
In other words, no one here would really know. I'd say start with a good wide deck and have it overhauled to meet your needs.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
Old 01-06-2014, 04:42 PM
jrs14855 jrs14855 is offline
Default cases
I don't have info on those pn's but the most common difference in cases is the front main bearing configuration. Many E series use the four piece 0 235 front main bearing while a few use the two piece bearing used on most other 0 320's. As previously posted there is also the issue of thick vs thin main bearings. The easy solution is to find a case and then call Divco or one of the other companies and ask them.
Old 01-06-2014, 04:43 PM
Default case
Also the 0 235 front main bearing setup will not support a constant speed prop.
Old 01-06-2014, 06:02 PM
I think it's about $145 to convert the 235 4 PC nose bearing to the newer 2 PC and support for constant speed.
Calling Divco or another good shop will be best.
Sid Lambert
RV-7 Sold
Old 01-06-2014, 07:56 PM
SHIPCHIEF SHIPCHIEF is offline
+ 1 on Call your Vendors!
They can be a great info source, often overlooked in the GOOGLE age.
When you find out, come back here and share the result. Use a few good key words so it can be found in the search function later.
Yes Vendor services cost money, but truely good vendors can prevent expensive mistakes and provide good choices.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 01-07-2014, 08:57 AM
659JR 659JR is offline
Default CASE
The LW-18379 is the 8 main case to fit the E2D and a few other models. The LW-18372 is the 6 main case with the full front main bearing if you want to run constant speed. It will fit the 320 or 360 engine models. Just like the others said CSI or any of the other case shops can convert them for a couple hundred dollars to the configuration you want. In most cases the crankcase castings are the same just the finish maching is different.
Jesse
Old 01-07-2014, 11:28 AM
Thanks Jesse - that is just what I was looking for. I'm gonna call Divco anyway because I'm interested in their O-ring case mod.
Marion IA
Old 04-02-2014, 11:02 AM
flyingriki's Avatar
flyingriki flyingriki is offline
I believe you mean Ly-Con for the O-ring.
Old 04-02-2014, 06:02 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
The ECI modification price list is here -
http://www.eci.aero/pages/repairs_cc...#Modifications
The mod you need -
CCM21 Modify Front Main for 2-piece Bearing $136.80
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
