Old 09-10-2006, 08:30 PM
Jim H Jim H is offline
Question RV-10 INSULATION KIT
RV-10 INSULATION KITS ARE NOW AVAILABLE FROM A COMPANY IN MISSOURI! TO FIND OUT MORE ABOUT THIS KIT ........ TRY THEIR WEB SITE@
WWW.SOUNDEXPRODUCTCS.COM
JUST RECEIVED MINE AND HAVE NOT INSTALLED IT YET. I AM GOING TO TAKE A db METER READING BEFORE AND AFTER. NOW WAITING FOR THE db METER.
I WILL REPORT WITH THE RESULTS WHEN FINISHED!
JIM H.
Old 09-11-2006, 08:18 PM
N62XS N62XS is offline
Default Link does not work
Jim, can you check the link?
IHN,
2020 Dues Paid
Robby Knox
THEM: Why do you always carry a knife?
ME: I can't open a bag of chips with my Glock!
Old 09-11-2006, 08:24 PM
fehdxl fehdxl is offline
http://www.soundexproducts.com/
(there was an extra c towards the end of ...products)
Old 09-12-2006, 04:39 AM
dav1111 dav1111 is offline
Super Moderator
Default RV-10 Insulation Kit
There price seems really high to me.
Russ Daves
N710RV (flying - out of paint shop this week)
Russ Daves
Lubbock, TX
Proud to be a Veteran
N710RV - RV-10 Sold
N65RV - RV-6A Sold
N686RV - RV-6A Re-Built, Sold
N742PZ - RV-8 Co-Builder Sold
N-867RV -RV-7 Finish Kit
Old 09-12-2006, 03:28 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default Pretty extensive coverage
I called:
The RV-10 kit is about 22 lbs and is extensive. It is all of the firewall, side wall from FW to aft baggage, floor and roof, so that may be part of the price. The kit is designed to install before the floor is riveted down. The floor insulation goes right on the belly skin, so should be installed during construction.
The RV-7 is 10 lbs. The extent of the RV-7 kit is similar except no roof. The floor insulation just sits on top so you can install it later. I assuem you will want to put carpet down. Not sure how the thickness will work? The insulation is 7/8" and 1-1/8" thickness.
Both kits come with material and templates to cut out the pattern to install.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
Old 09-12-2006, 03:37 PM
MichRV10 MichRV10 is offline
Flight Line interiors sells the matting for alot less. I used their material and it works great.
You have to cut the pieces but it is not that hard.
3135F Flying and having fun.
Old 10-02-2006, 03:55 PM
w1curtis's Avatar
w1curtis w1curtis is offline
That Flightline stuff is regular garden variety dual sided foil thermal insulation. The SoundEx stuff is a three layer, thermal and sound insulation. I do agree however that the kit is pricey. I plan to buy bulk sheets, rather than the kit, and roll my own only to those areas I deem important.
William Curtis
SB RV-10 40237, Status, Panel, Engine, Paint, Me, NE RV-10 Page, Cessna 177RG, AF Missions
?Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.? - Dr. Suess
Old 10-02-2006, 07:01 PM
Mark's Avatar
Mark Mark is offline
Buy four Bose Headsets and save $400 and a few pounds.
Mark
N410MR (Flying)
Old 10-02-2006, 07:55 PM
Mark's Avatar
OOPS - should have checked my math before posting. Four Bose Headsets add up to $4,000 not $400. Sorry about that.
Mark
Old 10-03-2006, 09:01 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default A cheaper way
Get 4 older headsets, Telex, David Clark, Sigtronics etc, and update with active noise reduction units from Headsets Inc.
They work great, and the price is right.
Mike
