Not an major item, I know, but isn't it nice to buy the right gizmo the first time?
I wanted a removable smartphone holder for a vehicle. Perusing Amazon, I found this one:
http://amzn.com/B008ALV0V4
Here's what I like about it:
- Not specific to any phone, so it will work with iPhone, Android, with or without case
- Attaches very securely via vacuum base or adhesive
- Not expensive
- Attaches to a variety of surfaces at different angles, even ones you might think a vacuum wouldn't work
I tried it in an Aircoupe I fly while building the RV-9A. The Coupe is not a smooth flyer, there's definitely some vibration in the cockpit, but this held my iPhone perfectly well for about 1.5 hours of flight and two landings.
Finally if you want a good cigarette lighter charger I like this one
http://amzn.com/B00B8M4IMK, which will charge both an iPad and cell phone simultaneously (if your cigarette lighter will supply the amps). Amazon Basics has good quality USB<->30 pin or Lightning cables for less than Apple's prices.
