Old 01-04-2014, 07:49 PM
airguy's Avatar
airguy airguy is offline
Default nose gear tube problem
I was assembling the nosewheel for my 9A this evening, and ran into a problem with the tube. This is the standard Vans parts list, direct from them in the kit, and the nosewheel tube valvestem is too long. It will not clear the nosewheel fork.
I'll obviously need a different tube - which tube are you guys running that uses a shorter valvestem for the nosewheel?
Old 01-04-2014, 07:58 PM
Greg it looks like you installed a main wheel tube. The smaller one for nose wheel has shorter stem. I replaced at least three all of them with short stems.
Old 01-04-2014, 08:34 PM
airguy's Avatar
I had 2 tubes with the short stems for the mains, and this one with the longer stem for the nose, are all the tubes identical size? If so I'll just get another similar to the ones I used on the mains.
Old 01-04-2014, 08:36 PM
Those two with shorter stems are BOTH for the nose. Vans usually ships two because it's so easy to pinch installing first time. My guess is you mixed them up but I was wrong before
PS They all are of different sizes. You can fit the main tube into front wheel but can't do vice versa. It's a possibility you received wrong tubes.
Old 01-05-2014, 05:50 AM
Walt's Avatar
Walt Walt is offline
The nose wheel uses the 11/400-5 while the mains are 500-5. I've never seen a 11/400-5 with a long stem.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 01-05-2014, 07:54 AM
10builder's Avatar
10builder 10builder is offline
Default Valve stem cap?
I know with the -10 I had to remove the yellow cap in order for the valve stem to clear the nose fork.
Brian S.
Arrington, TN
SPA Panther N87XP
RV-10 N104BS (Sold)
2020 VAF donation cheerfully submitted!
Old 01-05-2014, 09:23 AM
airguy's Avatar
Looks like I'm going to pull all of them apart today to verify part numbers and make sure I know what I've got, and get them in the verified correct location. I'm about 98% certain I only have 3 tubes total - I'll have to go through all my boxes again carefully to make sure, but right now I'm fairly sure Van's shipped me two nosewheel tubes and only one main.
Old 01-05-2014, 09:27 AM
rvbuilder2002's Avatar
For future reference, aircraft tubes air designed to be nearly net size to teh tire the go inside of. I.E. if you put in just enough air to make them fill out, they will be about the same size as the tire the are intended to go in.
Scott McDaniels
Hubbard, Oregon
Old 01-05-2014, 11:40 AM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Greg, ditch those pack front wheel bearings. You will be super glad you did!
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 01-05-2014, 05:54 PM
airguy's Avatar
Well you guys were right (as you already knew you were), I had the wrong tubes. I was just certain that I had only three tubes delivered to me, and put the matching pair in the mains and the odd one on the nose - but after digging down in the bottom of some boxes I found the 4th tube - sure enough I had the nosewheel tubes in the mains, and manage to cram a mainwheel tube in the nose. All is corrected today.
Darrel - you've got my attention - what are the options?
