I purchased one of the $19 grounding blocks from Stein (
http://www.steinair.com/storedetail.cfm?productid=310) and mounted it on the firewall near the battery, in the cockpit. I'm bringing the bulk of my grounds there (all the avionics, the EFIS's, AHRS, VPX-Pro, and all 10 of the VPX switches) to this ground. Its the screw kind of ground bar that uses the crimp on ring connectors.
I can either stack 2 or 3 ring connectors under each screw, or I can take the 10 switches, and perhaps some of the other low voltage wires and splice up to 3 onto one wire and take the single wire to ground. The latter method seems neater but potentially adds a failure point (the soldered splice).
Is one method preferable to the other?
