Old 01-01-2014, 03:35 PM
WVM WVM is offline
Default Superior vs Lycoming 320
Hi,
An owner of a Superior engine told me that his engine is around 15% more fuel efficient over the same Lycoming model. An engine mechanic told me that this is unproven, but not impossible, still probably a Lycoming engine will be as efficient as the Superior on the same airframe. He expect the difference between both to be not that big.
I think to put a XIO-320-D1A from Superior on an RV9, does anyone has information on the fuel burn?
Thank you
Old 01-01-2014, 04:22 PM
N941WR's Avatar
N941WR N941WR is offline
I went with an ECi O-360 when I replaced my engine a few years back and am very pleased with the results. 50-55% power, 150-155 Kts, while burning 7.2 GPH in cruise. My empty weight is in line with O-320 powered -9 at 1068 lbs. Climb rates can go over 2,000 FPM with a FP Catto (solo and partial tanks.).
You have a lot of options.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 01-01-2014, 05:56 PM
RV6_flyer's Avatar
Originally Posted by WVM View Post
Hi,
Thank you
Most of the parts in the Superior engine are PMA parts that could be used in a Lycoming. I do no believe that there is a difference in fuel burn if they are producing the same power.
Who ever told you there is a difference needs to "Show Me" as I am from Missouri the show me state.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 01-01-2014, 05:59 PM
diamond diamond is offline
Bill
What is your burn rate down around 115 knots?
Old 01-01-2014, 06:21 PM
N941WR's Avatar
Originally Posted by diamond View Post
Bill
No idea, I never fly with Cessnas.
Bill R.
SC86 - Easley, SC
Old 01-01-2014, 06:29 PM
Sid Lambert Sid Lambert is offline
I remember about 10 years ago Superior had a sump for an updraft carb they claimed was more efficient. It had a small divider that directed airflow to each cylinder.
Other than that I think everything else is PMA and the same as Lycoming.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
Old 01-01-2014, 06:34 PM
Steve Melton's Avatar
Default same fuel burn as Superior O-320
my fuel burn is 7.2 GPH, 9K, 153 kts, WW200RV prop on Superior O-320 at 65% power. climb rate also greater than 2K FPM. oil cooler 90% blocked in winter oil temp = 175F, in summer with no oil cooler blockage it does not exceed 190F. a cooler engine may be a benefit if running mogas.
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
Old 01-01-2014, 06:36 PM
N941WR's Avatar
Only you can order up roller tappets, different compression pistons, cold air sump, etc. which all improve performance.
ECi has their own performance tricks for the experimental market.
Truth is, you can't go wrong with either engine and once you hang it on your experimental airplane it becomes an experimental engine.
Bill R.
SC86 - Easley, SC
Old 01-02-2014, 04:34 AM
WVM WVM is offline
Nice one...
Does anyone with a (I)O-320 Lycoming or Superior know what the fuel burn will be around 115-125 kts?
Old 01-02-2014, 05:51 AM
C-FAH Q's Avatar
C-FAH Q C-FAH Q is offline
IO-360 200hp is economical as well.
http://www.flickr.com/photos/1132102...in/photostream
Gary Wilcox
St.Thomas, Ontario. CYQS
RV7 Sold
www.Facebook.com/Purplehillair
www.purplehillair.com
C-FAH Q now N281CT
gwilcox3 @ gmail.com
