Old 12-30-2013, 03:49 PM
mill2978's Avatar
mill2978 mill2978 is offline
Default Can I repair this double drilled rib?
One of my ribs ended up with a hole that was double drilled. This is on the leading edge of the outboard most rib on the right wing. The skin is fine, it is only the rib.
Can I place doubler underneath it, use another technique to repair it, or is it time to order a new rib?
In the photo you can see a 1097 4-4 "oops" rivet that I was considering trying to use, but I don't think that will work.
Thanks for the help
Aaron Miller
RV8 N127KT - First Flight October 16, 2018
http://www.mykitlog.com/AaronMiller/
Old 12-30-2013, 04:17 PM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
Default Build On
I'd just install the oops rivet and build on. I most certainly would not buy another rib. Keep on truckin'
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
Old 12-30-2013, 05:25 PM
DanBaier's Avatar
DanBaier DanBaier is offline
I'd probably dremel off the mis-drilled part, fabricate a replacement with a similar bend from sheet and rivet that to the rib securely (at least three places). Then, match drill to the new piece and keep building.
Dan
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
Old 12-30-2013, 05:48 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
If you're not going to do the replacement and make a patch, +1 what Dan said at least.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 12-31-2013, 10:24 AM
longranger's Avatar
If this is your first mistake, shell out the $25 and buy a new rib. The next time you screw up a tab, cut a section of flange out of this rib and splice it in. Just make sure it's the same or thicker material.
I did it when I mis-drilled a tab on my F-712 aft bulkhead. I needed to shim the tailspring mount anyway, so I just killed two birds with one stone. The material was from a rib or spar I'd screwed up sometime earlier in this adventure. Already had an nice flange bent in...
RV-7 TU 904KM (reserved)
Construction Log
Old 01-01-2014, 04:15 AM
Arie's Avatar
Arie Arie is offline
Default Doubler
I would deburr the fig 8 hole, then dimple the right hole and make a doubler that fits the tab ,out of the same thickness or thicker aluminum sheet .Then sandwich it all together when you get to rivet the rib in place.
Old 01-07-2014, 10:44 AM
mill2978's Avatar
Default replaced
Thanks all for the advice. I needed some other items from Vans and decided to replace the rib rather than repair it.
Aaron Miller
