Old 12-30-2013, 10:00 AM
BGordon's Avatar
BGordon BGordon is offline
Default Panel Planning
Good morning everyone,
I am starting to lay out my panel to see where I want stuff and how much room will be available. I always see others with nifty scale cut outs of things such as steam gauges, radio stacks, etc... Does anyone know where I can find these so that I can do the same?
thanks in advance
Brandon
Brandon Gordon
KFWS, Burleson, TX
Old 12-30-2013, 10:52 AM
cfiidon's Avatar
cfiidon cfiidon is offline
Many of the equipment manufacturers show cut outs on there web sites, typically in their "support" section.
Their installation manuals also provide dimensions, so that you can do it by hand.
I also recommend you buy a cheap copy of Turbocad for making switch drill templates and label panels... We'll worth the 15 bucks or so.
I also used a software panel planner that had all the equipment templates, can't remember the name right now... Senior moment!
Google to the rescue... Xpanelsoftware.com
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 12-30-2013, 11:07 AM
Dbro172's Avatar
Dbro172 Dbro172 is offline
Default Draft sight
Draft sight has a good free cad download and in fact there is a link to it on Vans support section of their website. If you're not familiar with cad you may need someone to help jump start you on the basic commands. There is also panel drawings on vans site you can open in cad. With this you can scale and place any image from the web.
I would usually grab an image from google (say of a garmin 430 for example) then lookup the dimensions in the 430 manual and scale the image to that. This works OK for planning.
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
Old 12-31-2013, 05:17 AM
SvingenB SvingenB is offline
This one is very nice. Here you can play around as much as you want to see of different layouts work. You can also "import" your own pictures of gauges and instruments.
http://www.xpanelsoftware.com/
RV-4 #4520, Slow built
B Svingen
RV-4 Project Log
Onex Project Log
EAA Chapter 573 Norway
