Old 12-25-2013, 03:02 PM
Barneybc12d Barneybc12d is offline
Default First time builder question
RV-14 tail started today. When the plans say to cleco skin to assembly and final drill..........do you cleco every hole and drill one at a time, or every other hole, or every third hole?
Santa was good to me this year.
Old 12-25-2013, 03:13 PM
eddieseve eddieseve is offline
Hi Barney,
I put a cleco in every second hole, then drill all the open holes, then move the clecos into the hole you just drilled and final drill the remaining holes before disassembly for deburing, dimpling and priming etc.
Enjoy the build.
Cheers
Eddie Seve
Sydney Australia
First Flight 16th July 2012
RV-7 Phase 2, 30 Oct 2012
1100 hrs Feb 2020
Old 12-25-2013, 03:22 PM
Thanks Eddie
Fitting good. Just using a reamer on the punched holes.
Old 12-25-2013, 05:01 PM
I cleco'ed every other hole when the sheet was flat.
I cleco'ed all the holes (pull and drill out one at a time) when the sheet was bent or otherwise stressed.
In other words, I tried to use some judgement.
Old 12-25-2013, 05:11 PM
If you have enough fasteners cleco every hole. Easier to work.
