12-23-2013, 05:46 PM
TC splices ?
I need to terminate my CHT and EGT wires inside the firewall. Do you have any suggestions how to do this ? Soldering will be a pain if you remove the engine. Terminal strips could bring conductivity &corrosion errors etc into the equation. Your thoughts ??? Larry
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
12-23-2013, 07:18 PM
Larry, I use these guys, a 3M product; you have to order both the male and the female disconnects. I alternate the sex on the cylinders on each side of the engine so you can't mix the cylinders up. A lot of the CHT/EGT sensors come with these. I have also seen the ones that look like small ring terminals that screw together.
http://www.mouser.com/ProductDetail/...#37;2f5KvKLcBM
and
http://www.mouser.com/ProductDetail/...YcrwZjBszi0%3d
I double over the end of the thermocouple wire to get a good solid crimp in the disconnects--they are made of hard plastic so it takes a good squeeze. Good idea to cover them with shrink tube, too.
Reason: Corrected the links...
12-23-2013, 07:43 PM
http://www.mouser.com/ProductDetail/...Wih%2f5KvKLcBM
and
Ditto for me. 500+ hours and no issues.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
12-23-2013, 08:27 PM
Don't forget, nothing lasts forever, so unless you got the best probes available (EI) many of the "economical" versions will need replacement after just 3-500 hundred hrs. so keep easy replacement/access in mind.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
12-27-2013, 02:01 PM
CHT and EGT Connections
I used two 8-connector terminal strips mounted on the engine side of firewall, one on each side about level with the brake fluid reservoir. The stock CHT and EGT bayonet connectors need to be replaced with ring terminals, and the EFIS sense wires need also to be fitted with ring terminals. This makes the replacement of probes much easier. If you are using a digital engine management system (such as a Dynon FD180), you can cut off the excess wire from the management system. These systems measure voltage directly with no current flow, so wire length is not critical. (Unlike analog Gages that require current to move the needle, making wire length - and total resistance - critical.)
I installed the terminal strips about 18 months and 300 hours ago. No problems have shown up.
Craig Taylor
RV8 flying
2020 VAF dues paid with thanks
Navy A7E Vietnam era
Ret. Corporate Pilot: G1159, IA Jet, Jetstar, Falcon 10, 20, 50
12-27-2013, 02:10 PM
No one has mentioned this, maybe it's obvious: these are thermocouple wires. If you connect them to anything else (like copper) you will introduce an error into the system, unless you treat both wires identically, in which case the errors cancel. This includes keeping the splices on both wires at the same temperature.
12-28-2013, 09:49 PM
Be Careful!
Bob Turner is right. You should not splice any copper wire into the TC circuit, as it will induce measurement errors. The right way to connect is using these plugs- http://www.omega.com/googlebase/prod...FcsRMwod_nAAGQ. They are made of the same material as the wire (alumel and constantan).
Doug Rohrer
Bowling Green, KY
12-28-2013, 10:21 PM
D-Sub
I used a d-sub terminal mounted through the firewall. Not flying yet so not sure how well this will work, however easy to disconnect and reasonably simple to change out the engine side when required.
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
First in line for the Sonex JSX-2T kit
12-29-2013, 01:48 AM
Originally Posted by Doug Rohrer
^^^^ Exactly right. This is the proper way to place a disconnect in the TC wire. These are available for all the TC types; ie, K, J, T. You need to specify what type of TC you have (EGT and CHT are usually different), as in chromel/alumel, iron/constantan, etc. Also, any extension leads you make-up must be of the same material as the TC's.
'83 LongEZ - N888EZ 3,671 hours
'89 LimoEZ - N26EZ 686 hours (sold)
A couple of Glasairs and a Lancair 320...
Next: a RV14 need something to build
12-29-2013, 08:15 AM
OMEGA and copper ?
Thanks for your helpful input everyone. Here is what I concluded:
1- My brother recommended Omega miniature connectors based years of experience at GE Aircraft and Cummins engine. You can even buy online from Omega. That's not saying the other ideas won't work equally well as you have referenced.
2- I must extend all 4 CHT and 1 EGT to reach the COPPER leads from my MGL TC instrument. Based on Rainer's input (MGL CEO), I will use copper Tefzel and silicone glass sleeving from B&C. The expectation is ; IF all dissimilar junctions are kept at the same temperature, error is insignificant in this application..Thanks again..Larry
Larry DeCamp
Clinton, IN
