Old 12-21-2013, 04:07 PM
omrsramsay's Avatar
omrsramsay omrsramsay is offline
Default Something on my flywheel
Can anyone tell me what this thing bolted to my flywheel is? I suspect it's some kind of automatic balancer. Should I keep it?
Thanks.
https://picasaweb.google.com/1174532...83960655336914
John Kimmel
http://www.youtube.com/watch?v=ZOa7Xsc2P_M
Old 12-21-2013, 04:32 PM
jrs14855 jrs14855 is offline
Default flywheel
Harmonic Balancer, probably made by Mark Landoll and no longer available. Generally used with wood fixed pitch prop.
Old 12-21-2013, 05:05 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Landoll fluid-filled balancer. Now that they are no longer made, they have become somewhat highly sought-after.
If you're going to continue running a wood or composite fixed pitch or ground adjustable prop, you definitely want to keep it.
Neal Howard
Airplaneless once again...
Old 12-21-2013, 05:11 PM
omrsramsay's Avatar
Thanks....
John Kimmel
Old 12-21-2013, 05:56 PM
erich weaver's Avatar
Not everyone agrees with this. I am not an authority on this subject, but Jim Fackler, who has a business dynamically balancing props and is well respected, is of the opinion that harmonic balancers are useless unless your goal is only to move the CG forward. Just FYI, I can't argue one way or the other.
erich
Old 12-22-2013, 01:39 PM
Smilin' Jack Smilin' Jack is offline
Default Hey John how's the repair coming
Just wondering if your almost done with the repairs... Or if you ever caught the guy or gal that caused all the damage
Smilin' Jack & Anita Hunt
N507H RV7, KJZP Jasper, GA
EAA690
APRS/ WB4JKY
Retired Corporate Pilot CFI-AI, MEL
CE500, LRJT, HS25, C650, SBJT, CL60
Hunt Aviation, LLC.
Pilot Service, IPC's Biennials.
Comm Glider
Old 12-22-2013, 07:16 PM
omrsramsay's Avatar
Default Up to the minute.
This is my up to the minute progress re-skinning the elevators.
https://picasaweb.google.com/1174532...04955811561938
John Kimmel
