Garmin Servos will work in either Dynon or Tru trak mounts.
You can use the existing wing or fuselage for the roll servo, and also the pitch servo will work. You will probably have to grind a slight relief for the motor housing, but the bolt pattern is the same.
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
