Go Back   VAF Forums > RV Firewall Forward Section > Electronic Ignition Systems
View Poll Results: Which spark plug adapter do you use?
EMAGAIR: Screw adapter onto plug and torque plug. 6 37.50%
LIGHTSPEED: Torque adapter, torque plug. 6 37.50%
Use 18mm Auto plug, no adapter 4 25.00%
Multiple Choice Poll. Voters: 16. You may not vote on this poll
Old 12-20-2013, 05:02 PM
swisseagle's Avatar
swisseagle swisseagle is offline
Default Plug adapter ... which one to use?
Hello,
I'm thinking about to convert to auto plugs. I have 2x PMAG, but with aircraft spark plug. I do not like the situation about the plug adapters. So the questions pop up: Which adapter do you use?
EMAGAIR:
Screw the adapter onto the spark plug and torque the plug? Sometimes the plug also came loose when plug is taken out.
OR
Lightspeed:
Plug adapter screwed in with desired tourqe. Then spark plug gets torqued. Adapter stay in when plug is taken out.
Dominik
RV-7A, TMX-IO-320, FM-150, Sensenich FP
Flying since 28. April 2016
Old 12-20-2013, 05:04 PM
Walt's Avatar
Walt Walt is offline
I prefer the Lightspeed units.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 12-20-2013, 05:09 PM
swisseagle's Avatar
Default Whow!
Whow Walt ... 2 minutes after putting this onto VAF, you allready answered!!! Ok, at your place it is still day, here it is 1 o'clock in the morning I should go to bed and see the results when the sun is up again.
Thanks!
Dominik
Old 12-20-2013, 05:13 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
I prefer to torque the adapter and then install the spark plug. Less chance damaging the spark insulator as most spark plug sockets have a fit rubber to protect the insulator. If the big socket for the adapter slips for any reason with the spark plug in the adapter, chances are damage can occur to the insulator. I still remove the adapter, clean and check condition and put new anti-seeze on both the adapter and the spark plug. So that would be Lightspeed.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
