Old 12-20-2013, 04:09 PM
Airhead Airhead is offline
Default Shimmy Redux and Resolved
Just wanted to post my recent experience with resolving the shimmy problem on my 7A. My shimmy/vibration was not so bad that I made it a high priority, but 50 hours after first flight, I decided to solve the problem. After spending considerable time reviewing the many previous posts and videos and varying my tire pressure and side breakout force (and refining my landing technique), I came to the conclusion that the breakout (side load) force is not the issue for the typically experienced "shimmy". I have not yet seen a video of a "fishtail" type movement (side to side) on the nose wheel. I have, however, seen many fore/aft shaking/shimmy videos and have observed this directly in taxi operations at my airport.
Also, I might note that the solution provided by Allan at ASA seemed to solve the problem with about 100 percent satisfaction. His solution has nothing to do with the side to side breakout force (or landing technique), but everything to do with bearing drag, wheel balance, and tire roundness. So, being one of those do it yourselvers (maybe one or two more out there), I decided to see what I could accomplish before I sent my wheel to ASA. By the way, I have Matco nose wheel with original split bushings, which if axle is tightened to prevent bushing spin produces a lot of drag.
Step 1. Per Matco tech bulletin, I removed the inner portion of the rubber seal. This reduces rolling drag buy maybe 50 percent.
Step 2. Trued tire (orig. Cheng Shin) with hand held belt sander, marker held steady using nose wheel fork (done with wheel mounted). About 30 min.
Step 3. Had wheel spin balanced at Spruce Creek FBO. $15.
Strep 4. Made alum. spacer (1" dia / approx. 1.3" long) using lathe (30 min.)to fit between the two bushings so axle nut can be tightned without affecting bearing preload. This accomplishes the exact same thing as the new type Matco axle. The last trimming of the length was done 1/1000th at a time to get the desired bearing preload.
Flight Test: Shimmy gone. (Don't leave plane without parking brake set now or it will roll off with mild breeze)
Bob B
RV-7A QB slider - IO 360 M1B Hartzell C/S prop w/Dual 10" Dynon Skyviews - Classic Aero interior. Florida (SFB) based. 170 hrs TT .
Old 12-20-2013, 06:06 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Thumbs up +++1
+++1 for the ASA nose wheel mod. Awesome! I just did the Mains too. Allan Nimmo has been Great to work with!
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 12-20-2013, 07:22 PM
Wayne Gillispie Wayne Gillispie is offline
My -10 NW starts the fore-aft shimmy at 14-15 kts GS. My tire is 5/16" out of round. Working on it soon. Thanks.
Good judgment comes from experience, and a lot of that comes from bad judgment.
