Old 12-20-2013, 03:37 PM
Joe Joe is offline
Default Dynon Autopilot Servo Rotation Limiting Bracket Issue
There's a thread in a Dynon Avionics forum regarding a trim problem caused by installing the Dynon-supplied rotation limiting bracket on the autopilot servo.
At least in my RV-8A, servo rotation is limited by the hard stops in the flight control system long before the rotation limiting bracket would come into play.
Maybe I'm missing something but why even install it in an RV? If you have done so, can you give me a rational reason why you installed it?
Joe
Joe Dubner
RV-8A
Independence, OR
Old 12-20-2013, 04:06 PM
bret's Avatar
bret bret is offline
Not that Murphy would ever get involved, but in the highly remote chance that the mechanical stops failed, it would HELP to keep the mechanism to go over center and lock a control? Just my thoughts, not an expert here.
Old 12-20-2013, 04:07 PM
RVDan RVDan is offline
Smile
My installation was the same- no way the servo can come close to over center. But... it made me feel better.
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Learn the facts. "Democracy dies in darkness"
Old 12-20-2013, 04:24 PM
Airhead Airhead is offline
Same here, can't hurt, might help.
Bob B
RV-7A QB slider - IO 360 M1B Hartzell C/S prop w/Dual 10" Dynon Skyviews - Classic Aero interior. Florida (SFB) based. 170 hrs TT .
Old 12-23-2013, 09:30 PM
BruceP BruceP is offline
Joe, I left a bracket off too. There's no way it can overcenter without something catastrophically happening and then that will be the least of my worries.
Bruce Peters
Bakersfield, CA
RV-9A, Flying 11/21/15
VAF#1145
Donation up to date 08/20
Old 12-23-2013, 10:34 PM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Default Left off
I did not install either. My aileron stop is non-stock, Delrin rod on aileron hinge bolt. My thought is this bolt will have to be gone for the stop not to function.
Cheers
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
Old 12-24-2013, 09:30 AM
Joe Joe is offline
Originally Posted by BruceP View Post
... I left a bracket off too ...
Originally Posted by RVG8tor View Post
I did not install either...
Thank you, Bruce and Mike. As I said, I was afraid I was missing something, but no: installing the bracket does no good and can possibly cause issues according to the manufacturer. Appreciate your confirmations.
Joe
Joe Dubner
RV-8A
Independence, OR
