Working on my weak area, the engine. The ignition wiring coming with my IO-360-M1B engine has a red cap on the end. I was trying to pull it off, but it was so tight that I accidentally pulled the gray wire end insulator, pin and spring off. Without second thought, I just screwed the spring to the pin, then used straight brutal force to push the pin back in to the wire. It's pretty hard to push in. Today, the more I think about it, the more I am not sure I should insert pin like that. I am looking for help here. The ignition wire end looks like the picture below (Hope I post the pic correctly)
