Old 12-18-2013, 10:20 PM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Default Goo under intake valve
I was finishing up my annual and was changing the spark plug so I took the opportunity to use my dental cam to look in the cylinders again. I did this before but was concentrating on the exhaust valves.
Today I looked at the intake valves as well and I find this black goo on the underside of the valves. I am not having any engine issues but wondered if I should be concerned. All 4 intake valves have the same look. I did keep the engine on a stand while building and would roll it 90 degrees and leave it for a while and continue this unit the engine and done a complete roll. I don't know if this might be related. I know did get some oil into one intake tube, it was then that I realized I was leaving the roll at each 90 point too long. I have 161 hours on the plane and it has been flying for 1 year.
Here is a picture, the camera is a bit damage, that is what the black streaks are from.
Cheers
Thanks for any help.
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
Old 12-20-2013, 09:46 AM
RVG8tor's Avatar
Default Anyone
Interesting, a lot of views but no comments, this is not the usual response time frame of VAF.
Cheers
Mike "Nemo" Elliott
KOCF
N800ME
Dues Paid 2019
Old 12-20-2013, 09:55 AM
rocketbob's Avatar
Normal, its due to oil burning on the valve face from valve overlap.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 12-20-2013, 07:06 PM
RVG8tor's Avatar
Default Thank You
It is funny what one does not know or think of. It is nice to have someone with experience fill in the blanks of my engine knowledge. Just in a new learning phase now that I am flying.
Cheers
Mike "Nemo" Elliott
KOCF
N800ME
Dues Paid 2019
Old 12-20-2013, 07:16 PM
rocketbob's Avatar
It also comes from oil being drawn between the valve stem and guide.
N8155F C150 flying
Old 12-20-2013, 08:35 PM
SHIPCHIEF SHIPCHIEF is offline
Bear in mind that an engine is 'not new' from the first start to the last. It's all about the mid-life condition, and how gracefully it ages.
We now have dental cams and engine monitors to go along with compression checks and oil analysis. Seeing it first hand is kind of new for many of us. Thanks for sharing.
These are a great aid to find problems early. Then repairs can be made and the useful life of the engine extended.
So get used to 'used but good' parts and how they look while in service.
Some power is lost when the valves and ports get coated with sludge and carbon, so this would have a negative impact on a race engine, but it's typical of an engine in regular service.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
