Old 12-18-2013, 02:44 PM
Stockmanreef Stockmanreef is offline
Default Question: Dimpling Screw Holes in Tanks
In the plans (RV-14) it says to use a C-frame and hammer to put in the dimples for the screw holes in the tank skins. Apparently this makes crisper dimples. I assume that a pneumatic squeezer will work for the job. I don't have a C-frame. I do have a hammer, but I think that the c-frame is the critical part of this exercise ;-).
Ken
Ken Stockman
Midland, MI
EAA Chapter 1093 member
FaceBook Page: Ken's RV-14
RV-14a (serial number 140073)
N73XP
Plane at hangar and the wings ON.
Old 12-18-2013, 03:14 PM
N941WR's Avatar
N941WR N941WR is offline
Check with Froggy, Pat, or one of the other RV builders there. They can give you a hand and might have a C-frame you can borrow for those few dimples.
The C-frame simply holds the dimples in the correct relation to each other.
The trick is to get the dimples, not so much what tool you use to get them. The tank skins are thicker than the rest of the skins, as you have probably noticed, thus dimpling them takes a bit more force. When I did mine, I found that using hand squeezer didn't produce as nice a dimple there as using the C-frame.
Best of luck!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
wirejock's Avatar
wirejock wirejock is offline
Default tank skin dimples
I'm not familiar with the thickness of the 14 tank skin but my 7 skins are thick.
Personally, I would seek out a c-frame within the Chapter or this community.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 12-18-2013, 03:35 PM
rvbuilder2002's Avatar
The reason behind the manual recommendation is somewhat explained in Section 5.5 of the Newly Updated Section 5 of the construction manual. You can find a copy HERE
The tank skins are a worst case situation...
Thick skin and large dimple size.
This combination requires a lot of force to form a crisp dimple. And they are right along the edge of a skin which you want to lay down nice and flat.
Most pneumatic squeezers don't have enough force, and even if it does, the yoke flexes causing a misalignment of the dies which ruins the dimple quality and makes for a wavy skin edge.
More info and discussion HERE in a recent VAF thread.
Scott McDaniels
Hubbard, Oregon
Old 12-18-2013, 04:40 PM
OK. I understand the issue. What if the pneumatic squeezer is in a C-frame? I have a monster steel tube Cframe with a Numatx hydraulic squeezer that I can attach to it.
It might also be possible for me to make something that I can use to hold a die and then use a hammer.
Thanks for the feedback.
ken
Ken Stockman
Midland, MI
N73XP
Old 12-19-2013, 04:49 AM
JanRV6UK's Avatar
JanRV6UK JanRV6UK is offline
Ken .. Why not try to make a dimple on a piece of scrap alu of the same thickness ?
Jan
Slooow RV6, no hole, builder in UK
Paid up for 2015 ...
