Originally Posted by ron sterba
Maxwell, well this is a point of discussion making on the owners part. I'm in a qua-dry as to what goes where on the busses. As I be told to look at a emergency your are in. Lets say you have a alternator failure. What would you as far as instruments go need to get to the ground? Efis and a comm radio at least on my part,maybe a transponder too. Im not sure which buss I would place the feed current on. As we get more builders with EFISs and how they set this up.I hope they will share.
Ron in Oregon
You might have a minor case of SIBOL (self-inflicted builder option lockup)
I once wired a steam gauge IFR RV with an elaborate E-bus, dual batteries, and independent feeds for dual electronic ignitions. Despite clear cad-drawn electrical diagrams and plenty of cockpit coaching, neither the owner or a third pilot ever really understood any of it.
VFR airplane? KIS is good. Forget fancy bus arrangements for dealing with an emergency which probably isn't. Each individual device has an ON-OFF switch. If you ever need to shed load just turn off the ones you don't need right then, and later turn one back on if you need it.
Most of the EFIS systems are available with their own backup battery. Just turn the master off; the EFIS remains live.
