Old 12-17-2013, 06:29 PM
Tram Tram is offline
Default Experimental repairs.. Can someone set me straight?
Hey guys-
I've always been under the impression per part 43; if you bought an experimental aircraft and DID NOT build it, this was essentially like purchasing a certified aircraft with regards to maintenance and repairs. As well as the condition inspection needing to be carrier out by a certified A&P.
Simple, preventative maintenance is basically all that is allowed, correct?
Old 12-17-2013, 06:34 PM
Toobuilder's Avatar
Nope. Anyone or anything can work on an experimental.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 12-17-2013, 06:38 PM
PCHunt PCHunt is offline
Not correct. You might try searching the forum, extensively discussed. Look for posts by MEL.
Bottom line, Any Person, including you, can do any and all work on your airplane. The only thing you can't do, is sign off the annually required Condition Inspection. For that you need an A&P. No IA required.
You can repair, modify, add on, etc. Just make sure to read your Operating Limitations for how to put the plane back in service after major surgery.
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
Old 12-17-2013, 06:40 PM
Don's Avatar
Don Don is offline
Michael is 100% correct. Anyone (competent or not) can work on an experimental aircraft.
The only thing you can't do is the annual condition inspection. To do that you need a Repairman's Certificate (poorly named, since anyone can repair anything) and that requires you to have built the plane (or some significant part of it).
Don Alexander
Virginia
RV-9A 257SW Purchase Flying - O-320, Dynon D100
RV-9A 702DA (reserved) Finish Kit IOX-340
www.propjock.com
Ok. Good to know.
Thanks for the quick responses guys.
Old 12-17-2013, 06:43 PM
FORANE's Avatar
FORANE FORANE is offline
Originally Posted by Tram View Post
Hey guys-
Incorrect.
Read the article in the link below as it sums up the topic well:
http://www.wanttaja.com/avlinks/MAINT.HTM
Lancair 235/340
RV-9A (2013 - 2016)
Old 12-17-2013, 06:44 PM
Geico266's Avatar
Geico266 Geico266 is offline
So, I can legally repair damage and do my own condition inspections?
Would I need an A&P or IA to sign off this work?
Please re-read the posts in response to your question. There is your answer, it is good sound advice.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
FORANE's Avatar
You may repair damage. You may sign off your own repairs.
You may not do your condition inspection unless you hold repairmans cert or A&P.
Lancair 235/340
RV-9A (2013 - 2016)
Old 12-17-2013, 06:45 PM
Arlen's Avatar
Arlen Arlen is offline
Here's a link to this info from the EAA Government Programs Office (agreeing with the advice offered above):
Arlen
Donation to VAF 10.29.18
RV-6, February '14, SOLD December '15
Old 12-17-2013, 07:19 PM
Terrible internet + a very quick user base = posts behind the times.
Thanks..
