Go Back   VAF Forums > Main > Safety
View Poll Results: Do You Check/Pump Brakes Before Landing
Yes 61 33.89%
No 92 51.11%
Sometimes, but not a habit 27 15.00%
Voters: 180. You may not vote on this poll
Old 12-17-2013, 10:21 AM
Toobuilder's Avatar
Default Do you Pump Your Brakes Before Landing?
Simple procedure question - I had it drilled into my head early on in my tailwheel flying to ensure the brakes are pumped up just before touchdown. If they are soft, I can either try fix it or at least plan for a "no brake landing".
The habit of pumping the brakes on short final has saved my bacon more than once... Just wondering how widespread it is.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 12-17-2013, 10:22 AM
Low Pass's Avatar
Low Pass Low Pass is offline
Yes. (blank space)
Old 12-17-2013, 10:33 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
This is one of the things Mike Seager teaches.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 12-17-2013, 10:43 AM
rvsxer rvsxer is offline
I was taught to do it on a retractable after extending the gear due to all the lines and fittings moving around. I still do it on the RV someimes.
Mike Hilger
RV-6 N207AM w/G3X, 1,800 hours +
South St. Paul, MN (KSGS)
A&P, EAA Tech Counselor
We're all here because we're not all there...
Old 12-17-2013, 11:14 AM
Bavafa Bavafa is offline
I seldom use the breaks unless I am told to take a specific ramp and need to break to make it otherwise I use them to some extend to make turns.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - SOLD
N258SM RV14A - IO390EXP119 - in progress
Dues paid
Old 12-17-2013, 11:57 AM
John R. Graham John R. Graham is offline
Yes. Part of the checklist.
- John
Old 12-17-2013, 12:02 PM
DougJ's Avatar
DougJ DougJ is offline
I check 'em.
A brake check before landing is a good idea in any airplane, and part of the checklist at some point after gear extension in many.
In the C-23 it was part of the approach checks. After gear extension we checked for brake pressure AND that the pressure returned to zero when the brakes were released.
I did my RV training with Mike Seager, and as Mike S. mentioned he teaches a brake check before landing as well.
Doug
Old 12-17-2013, 01:49 PM
F1R F1R is offline
Default But not with Ice or snow
Ordinarily a good practice. However with snow or wet runways in freezing air temps on take off(and a landing to follow) I don't touch them on taxi, take off or landing to prevent locked discs.
Old 12-17-2013, 02:13 PM
Toobuilder's Avatar
Whether you use them or not, it's nice to know they are available...
I have returned from a long cross country to find a brake soft on short final. Better to address the issue in the air rather than on the ground in the heat of the moment. Also agree that the RV line is pretty benign on the ground, but not all airplanes are so well behaved. This habit carries over from one of my less well mannered airplanes.
Michael Robinson
______________
RV-8 - SDS CPI
1984 L39C
Old 12-17-2013, 02:20 PM
AX-O's Avatar
AX-O AX-O is offline
Yes.
I tap them after takeoff and during my landing checks. I don't use my brakes either but don't want to find out there not working when I need them.
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
The information that I post is just that; information and my own personal experiences. You need to weigh out the pros and cons and make up your own mind/decisions. The pictures posted may not show the final stage or configuration. Build at your own risk. Further more, these are my opinions and not those of my employer.
