Riveting technique Cleveland
When replacing brake pads, do you let the pad "float" a little on the backing plate? Or do you "pin it down" with the rivet setter? Found the O ring facing the wrong way today... so pulled everything for fresh pads, 5606 (I hate that stuff) and general clean up.
"Kindness is never a bad plan."
exemption option waived. Donation appropriate.
