Old 09-07-2006, 02:43 PM
Paul Eastham's Avatar
Paul Eastham Paul Eastham is offline
Default How to remove inter-cylinder baffles?
Subject says it all...seems like they're attached with some sort of tension/spring fit. I am thinking about removing them in order to:
- remove debris that I believe is down there (from baffle trimming)
- drill holes in bottom for baffle-attach safety wire
And how to reinstall -- looks like there's some RTV down along the bottom fins? (installed by Aerosport)
Naturally if this is a risky or difficult thing I'll find other ways to accomplish the above.
Paul Eastham - Mountain View CA
RV-9A standard build, flying! ~300 hrs
EAA Chapter 338 San Jose
Old 09-07-2006, 04:17 PM
Ironflight's Avatar
VAF Moderator / Line Boy
When I was at Mattituck to have my engine built, they had a slick tool to install those silly things...John told me to "watch close", becaue it happened in the blink of an eye....not sure I could duplicate the magic!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 09-07-2006, 07:46 PM
ddurakovich ddurakovich is offline
A "tiny" meat hook is what it looks like.....
I've used a pair of vise grips. Grab at the top of the curve and pull.
Takes about 10 seconds after you've done it a time or two!
Dave Durakovich
CFIG, AGI, COMM SEL, VAF# 133
RV-4, N666PR, Finished (Well, at least flying)!
RV-6 - Adopted an orphan!
Detroit, MI
"If you think you can do a thing or think you can't do a thing, you're right."
Henry Ford
Old 09-08-2006, 06:29 AM
N797RV's Avatar
N797RV N797RV is offline
Check out the cotter pin remover at Sears
http://www.sears.com/sr/javasr/produ...id=00904319000
This thing works like a champ, you have to "slip" the baffel part in with a rubber mallet.
Dick
N797RV - KSFB
RV-7A Flying
Old 09-08-2006, 07:44 AM
RV8N RV8N is offline
Default Use safety wire
Just slip a piece of safety wire under the hook. Clamp your safety wire pliers to it and as you pull up, push the cross bar down and to the side. Very simple and fast.
Perform the above procedure in the reverse order to re-install.
Karl
RV-8 #80240 SOLD
1999 BMW R1100RS
Old 09-08-2006, 08:37 AM
sf3543 sf3543 is offline
My method is similar to Karl's. Use safety wire but I also use a length of wood dowel as a lever. Wrap the safety wire around the center of the dowel. One end of the dowel on the cylinder base or on the case and then use it as a lever to pull up on the hook. This allows you to either install or remove the intercylinder baffle easily.
Works for me and no special tools required. You can even reuse the safety wire.
Steve Formhals
A&P, Tech Counselor & Flight Advisor
RV3B
RV8
Old 09-08-2006, 03:02 PM
zkvii's Avatar
zkvii zkvii is offline
Talking watch carefully - blink - done....
The tool (and John) that Paul was talking about -
(I really should get those words sorted.... http://www.rvproject.gen.nz/enginebuild1.html#ID2685
Carl
ZK-VII - RV 7A - New Zealand - NZNE - 700 hrs (2008 -2020)
TMX OF-360 (FADEC), Dual GRT H1, Garmin 430 / SL30 / 327, TT VSVG
