Go Back   VAF Forums > RV Firewall Forward Section > Fuel Injection Systems
  #11
Old 12-17-2013, 03:58 PM
BillL BillL is offline
FYI - Be sure you use hose made for aviation. Static electricity can build quickly in insulated hoses and will perforate the hose and make it weep. Right over the exhaust system. Aviation hose has a conductivity requirement for this reason.
A 3/8" id hose can build as much as 30,000 volts in a few inches.
Bill
RV-7
Lord Kelvin:
Old 12-18-2013, 07:56 AM
IF you are going to use teflon, definately use a conductive liner. Most industrial shops that make teflon hoses use a non-conductive liner (white). Be advised!
Tom
Ridgeland, SC
Old 12-18-2013, 08:25 AM
Capflyer's Avatar
Capflyer Capflyer is offline
The shop I use sells Parker hoses and fittings, some of which are aerospace products. I'll double check to be sure they have the correct hose for the fuel line. Thanks for the heads up. It's a pretty cool place to go into....kinda a candy store for hoses and fittings. You can find just about anything there.
Mike
JAMES AIRCRAFT.com
Flying - RV8 Hot Rod "Drone Killer"
Flying - RV8 "Look'n Good"
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
Old 12-18-2013, 11:24 AM
Yep they do have some neat things. Tell them you want 919B hose and you'll be just fine----they may or may not have 124. Steel hose ends are perfectly acceptable for our applications. Oh----and be sure to firesleeve the hose!
Tom
Ridgeland, SC
