Go Back   VAF Forums > Model Specific > RV-6/6A
Old 12-15-2013, 01:36 PM
JanRV6UK's Avatar
JanRV6UK JanRV6UK is offline
Default Tip up side skirt overlap on fuselage
Appreciate some feedback from anyone who has made the canopy skirt overlap the fuselage ? So far the following photos show my work up to now ? Not sure about the gap required between the skirt and the fuselage ? To stop it scratching off paint. My thought is to have a gap of .025 to .032. Then use a strip of the flap tape on top of the paint once that has been done ..
Jan
Slooow RV6, no hole, builder in UK
Paid up for 2015 ...
Old 12-15-2013, 02:07 PM
Brantel's Avatar
Brantel Brantel is offline
Made mine from layed up glass. They hang down about .75".
I put a few layers of duck tape on the fuse prior to laying up.
Have had no scratches to my paint.
I do have the guide blocks on the rollbar to help keep the canopy in line as it closes.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 12-15-2013, 04:17 PM
Default tipper skirt
Jan, I think your aluminum skirt will be more durable than a F/Glass skirt. I like your clearences. The 7 canopy skews left/right while opening/closing.
I imagine that the 6's are the same. As Bantel stated, Guide blocks are a must IMHO. Looks good!
Lorne
RV 7a tip-up
Pre-cover MD-RA Inspected.
Old 12-15-2013, 07:27 PM
johnfurey johnfurey is offline
I did the same as Brantel and very happy with it
John Furey, RV7. Ohio
Life's Short...Fly Often!
Old 12-15-2013, 07:32 PM
flytoboat's Avatar
flytoboat flytoboat is offline
Where do you get the guide blocks? Or did you make them?
Don
VAF #1100, EAA864
-6A bought flying
Old 12-15-2013, 08:23 PM
Brantel's Avatar
Made them out of a white plastic cutting board from Walmart if I remember correctly.
Old 12-15-2013, 08:27 PM
flytoboat's Avatar
Is there a pattern, or is it in the plans?
Don
VAF #1100, EAA864
-6A bought flying
Old 12-15-2013, 08:41 PM
Brantel's Avatar
No, this is a user mod that many have done.
I will try and find a pic....
Old 12-15-2013, 08:44 PM
flytoboat's Avatar
That would be great. I'll send you a pm with my email address.
Don
VAF #1100, EAA864
-6A bought flying
Old 12-15-2013, 08:49 PM
Brantel's Avatar
Robbed from other post on this forum:
http://www.bullerent.com/CanopyGuide.htm
Here are mine. I ended up putting an 1/8" spacer behind these:
There are more variations in the archives....
