Old 12-13-2013, 10:03 AM
moll780 moll780 is offline
Default oil level gauge tube gasket
I have a leak and need to replace this gasket.
I called Aircraft Spruce but they dont show a part number for the gasket.
Anyone recommend a source for this part?
Its the gasket at the base of the tube where it screws into the engine.
thanks!
--2008 RV-9A
Austin TX
Old 12-13-2013, 10:12 AM
BillL BillL is offline
We put a new 0-320 in our club 172. On first annual I helped our A&P with the engine portion. I noticed that the tube was loose and leaking, I grabbed it and hand tightened it. He said it was not worth the effort to torque and re safety wire. Later at OSH I talked to a guy at the LYC tent, he told me that it would come loose twice, just to retorque, re-safety and after the second time it would not leak again.
I don't know if this is fact or not. Some of the long time Lyc guys should confirm, but that is the story.
I hate leaks and plan to address each one to keep the engine dry.
Bill
RV-7
Lord Kelvin:
Old 12-13-2013, 10:23 AM
I'd also rather not have it leaking.
I've re-torqued it several times already and fear that if will put any more pressure I will crack it or worse.
I have my conditional coming up in Jan and want to take care of this when I have the cowling off.
--2008 RV-9A
Austin TX
Old 12-13-2013, 10:54 AM
rvbuilder2002's Avatar
Search the archives here in the forums... there is already a lot of previous discussion and lot of different remedies for making it not leak again.
The best one is stop over tightening the dip stick.
Most everyone tightens way beyond what is needed. Then the engine cools and it requires a high torque to get it loose during the next preflight. That is when the tube turns and breaks the seal.
1/8 of a turn Maximum, after the o-ring contacts the tube, slightly less is even better. It is more than enough to keep it from coming loose.
Scott McDaniels
Hubbard, Oregon
deek deek is offline
Use a piece of thin silicone baffle material and make your own - the preload from the silicone will prevent it from coming loose and it will never leak. Be sure to safety wire it up though
'83 LongEZ - N888EZ 3,671 hours
'89 LimoEZ - N26EZ 686 hours (sold)
A couple of Glasairs and a Lancair 320...
Next: a RV14 need something to build
Old 12-13-2013, 11:44 AM
cfiidon's Avatar
cfiidon cfiidon is offline
Default Tite-Seal
Mine started leaking and a I applied a copious amount of Tite-Seal. So far, so good.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 12-13-2013, 12:27 PM
az_gila's Avatar
az_gila az_gila is offline
Thumbs up
Or buy the certified thick silicone one from Real Gasket, much better than the thin cardboard Lycoming one -
http://www.ebay.com/itm/LYCOMING-DIP...-/271291171699
RG-72059 DIPSTICK TUBE BASE GASKET PMA Each $3.00
From here -
http://www.realgaskets.com/files/horizontal.htm
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 12-13-2013, 10:11 PM
done.. ordered two. I will not over tighten.
thanks!!
From here -
--2008 RV-9A
Austin TX
Old 12-20-2013, 08:29 AM
dougmattson dougmattson is offline
I ordered one of the gaskets from real gasket. Do you install these dry? coat with oil? Silicone grease? RTV?
9A flying
