Old 12-11-2013, 01:01 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Bob Olds Landing Light Lens
My -6A has the Bob Olds style landing lights (automotive, dual-filament halogen bulbs). The light cutouts on the leading edge are larger than the Duckworks. Both of my lenses need replacing due to cracks. Does anyone have an idea where I might find replacement lenses?
Thanks for the help.
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 12-11-2013, 02:10 PM
Bevan Bevan is offline
I believe Vans sells just the lenses and they come oversized for Duckworks. Not sure if they would be big enough for what you need? I'm wondering why they would need to be significantly bigger for a different vendor's product. Perhaps post a size requirement.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 12-11-2013, 02:48 PM
Mark Albery's Avatar
Mark Albery Mark Albery is offline
I needed the same a few years ago. The folk at duckworks were able to make them at reasonable cost based on a couple of photos and some measurements.
I had a spare, but that went with the aircraft when I sold it.
Old 12-12-2013, 05:40 AM
RONSIM's Avatar
Default Thanks for the replies
I bought a couple of the Duckworks, thinking they would be the same --- considerably smaller ---- I will check with Duckworks to see if I could do a "trade-in", and will also check with ACS -- I know some people make their own by heating and bending some plexi or Lexan. ---- might be fun to try.
Ron
Old 12-12-2013, 05:51 AM
fixnflyguy fixnflyguy is offline
Default Make them
I made my own, which are large, and similar to what you have. I used .125" lexan from the Lowes Aviation Dept, cut a little larger than needed, warmed in my home oven to just over 300 degrees then pulled over a piece of aluminum I formed to match wing L/E contour. Took about 30 minutes to make both. Trimmed and drilled to fit.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 12-12-2013, 11:56 AM
RONSIM's Avatar
Default Sounds like a winner
Fixnflyguy ------ great info and sounds like something I will try ---- If it works, I might just make a new canopy! (just kidding --- !!)
Old 12-12-2013, 12:19 PM
txaviator's Avatar
txaviator txaviator is offline
Ron
If you are going to try and form one on your own Ron, use Lexan (trade-name for polycarbonate). It is MUCH tougher, just as easy to heat form as acrylic, and MUCH easier to drill and cut versus Acrylic / Plexiglas. Our shop cuts and forms this stuff all day, every single day, for our products. Should be a rather simple project! No, really! See post #5. That's how ya do it!
Gary Robertson
Arlington, TX
RV-12 Built / Sold / Flying
Currently Flying: Cessna Skyhawk 172
Rebuilding a true barn find J-3 Cub
Old 12-13-2013, 12:26 PM
RONSIM's Avatar
Default Wilco - Lexan
Gary, thanks ---- Lexan it is!
Ron
