Old 12-10-2013, 01:01 PM
Kitfoxbill Kitfoxbill is offline
Default RV-7 static line water trap
I removed the 90 degree and installed a tee so water would be trapped below the line running Forward. Is this overkill.
[IMG][/IMG]
William Bennett
RV8A flying for sale
RV7 insterments
Old 12-11-2013, 06:02 AM
Walt's Avatar
Walt Walt is offline
I've yet to find any water in an RV static system but the drain point certainly won't hurt anything, assuming it doesn't leak (every connection is another possible leakage point).
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 12-11-2013, 06:10 AM
mburch's Avatar
mburch mburch is offline
If I am interpreting the photo correctly, it looks like the static line is running down the F-728A bellcrank channel to the fuselage floor, then forward through the F-708 bulkhead. At least in my copy of the plans, the static line is meant to run forward along the longerons instead. I'd have to think about it to be sure if it matters in terms of water ingress. Perhaps you already considered this when you chose this routing for the static line?
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
