Old 12-10-2013, 11:26 AM
digidocs's Avatar
digidocs digidocs is offline
Question Bypass valve on mechanical pump?
What is general consensus on installing a bypass check valve around the mechanical fuel pump?
It seems that many RVs just push the (electric fuel pump) fuel through the mechanical pump instead of using a bypass valve. Do most certified ships do the same?
David
