Old 12-08-2013, 06:33 PM
rwayne rwayne is offline
Default flow matched injectors
So my GAMI spread is unacceptably high. I understand I need to flow match my fuel injectors so the cylinders EGT peak within a fuel flow of 0.2 gph. It may be an obvious question, but how do I flow match my injectors?
Old 12-08-2013, 06:50 PM
The guys at Airflow Performance can help you take the data, make recommendations, and sell you injector inserts.
Basically if you start rich and lean, the cylinder whose EGT peaks first is the leanest, you need a larger insert; last to peak is richest, needs a smaller insert. But make sure you still get rated fuel flow with full throttle.
Old 12-08-2013, 07:23 PM
Kahuna's Avatar
Kahuna Kahuna is online now
http://mstewart.net/super8/nozzles/index.htm
Kahuna
6A, S8 ,
Gold Hill, NC25
Old 12-08-2013, 08:08 PM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default you change the nozzle size to shift the EGT peak...
After you determine the EGT curves you change out the nozzle inserts as needed to shift the peaks closer together... you get a wee bit bigger one to flow more fuel to shift the peak earlier (shift the curve left on the graph) or use one that is a wee bit smaller to lean the the cylinder mix shift the peak later (shift the curve right).
The standard nozzle is 0.0280
Special nozzles are in increments of +/- 0.0005 (so a +1 is 0.0285)
Airflow Performance sells the special restrictors for 25 each.
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
Old 12-08-2013, 11:09 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
First of all, please post the data you collected for both the GAMI lean tests you did. One I assume at say 7500' and one at say 3000' at the same MP and RPM you had when at 7500'.
Then once we are sure you have no intake leaks, analyse the data.
What is your GAMI spread now and how did you determine it?
The reason for my cautious questioning and suspicious tone is that if you are asking these questions it is a sure sign that you may not really understand how and why you do the tests the way you should.
Happy to help.
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
Old 12-10-2013, 05:58 AM
Default Air Performance
Thanks everyone. Great input. I'm going to go the Air Performance route. I've used Savvy's recommended flight profile and program (outstanding!) but think I'll leave the actual size determination and fitting of restrictors to the pros.
