Paul;
My T-18 has Bendix mags (well, now it has one) which have slotted ears that fit over the studs from the accessory gear case. Just a nut and washer retains these mags to the case and the movement to rotate the mag is limited by the slotted holes.
A quick look at a picture of a Slick mag, and I see the same mount flange as the P-mag. Now I understand. I would have bought a set of Slick Mag hold down clamps had I known.
So your memory is fine. Thanks for commenting, it jogged me enough to figure it out. (I've never had a plane with Slick mags before)
Maybe I'm being a bit picky, but the whole P-mag thing is so well done I was suprised this part had no note or accessory part etc.
Or maybe I'm a candidate for the 'Brown Bag'
The P-mag is great, as expected. I got an additional bonus: my comm radio quit acting up! The old assembly must have been periodically arcing inside or something, and the radio was auto squelching as hard as it could to suppress the noise, leaving me with a strangely weak radio and blasts of static, except when testing on the ground (of course)!!
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is
nothing-absolute nothing-half so much worth doing as simply messing around with
Aeroplanes
(with apologies to Ratty)
2019
