Old 12-07-2013, 11:37 AM
nekit nekit is offline
Default Cleaning Carbon out of Cylinder Head
Rebuilding a fairly low time O-320. Wondered if anyone had a trick tool for cleaning carbon deposits in combustion chambers, with the cylinders off the engine. On automotive heads I've used wire wheel and scotchbrite wheels. With the attached cylinder configuration of aviation heads it a little harder.
Any insights on tools or chemicals that help out?
Rob
Old 12-07-2013, 11:54 AM
Geico266's Avatar
Geico266 Geico266 is offline
Try using a gun powder solvent like Hoppes #5. I think that is the name of it.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 12-07-2013, 12:06 PM
rocketbob's Avatar
Pricey but this stuff works awesome.
http://www.ppg.com/coatings/aerospac...on_Remover.pdf
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 12-07-2013, 12:29 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
I think it is #9, not 5??
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 12-07-2013, 02:07 PM
rocketbob's Avatar
Hoppes won't touch carbon buildup. In fact I find it barely usable on guns. Like the smell though for some strange reason.
Nothing the average consumer can buy from an auto parts store will soften carbon deposits. Been there done that.
N8155F C150 flying
Old 12-07-2013, 03:53 PM
BillL BillL is offline
Bob,
Maybe the grocery store . .
In my former employers' development lab, the fuel systems guys used a detergent bath heated to 180F. They used a fancy product, but said they would use Wisk mixed rich with water too when they ran out. It would soften and break loose the diesel combustion carbon deposits on injectors, even in the orifices. I tried this on some parts at home and and it easily cleaned the varnish from lifters, connecting rods etc. It smells up the kitchen.
I might be concerned about aluminum, though, due to the resulting pH. No help to the OP in that regard. YMMV.
Bill
RV-7
Lord Kelvin:
Old 12-07-2013, 04:35 PM
rocketbob's Avatar
There are lots of detergents that will work but what effect do they have on the aluminum...that's the thing. Simple Green should work but I'm not sure I would use it. In the shop I have the PPG product and I put whole cylinders in a turkey fryer pot I throw on the stove for a couple of hours, and that usually gets things nice and clean.
N8155F C150 flying
Old 12-07-2013, 09:22 PM
Wayne Gillispie Wayne Gillispie is offline
I have used a heated ultrasonic bath with mild dish soap solution for 15 minutes, then used walnut shell or plastic media in a blast cabinet. Use as mild a solution and as little pressure as possible to accomplish the job.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 12-08-2013, 12:47 AM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Post some photo's!
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
Old 12-08-2013, 01:28 AM
Ultra's Avatar
Ultra Ultra is offline
WD-40 and scotchbright. worked a treat decarboning my old 2 stroke rotax pistons and head.
