Old 12-04-2013, 08:08 AM
Tomas J's Avatar
Tomas J Tomas J is offline
Default Brass Tee for fuel primer system
Hi,
Anyone knowing where I can buy this typ of brass Tee? It's for the fuel primer. AS have all the other stuff for making a steel tube primer system. But I can not find the Tee.
Tomas Johansson
Flying RV-4, and Super Cub on floats and skis
in Northern Sweden in Skandinavia
Old 12-04-2013, 09:54 AM
JDanno JDanno is offline
try McMaster-Carr.com as I just looked there for "brass tees" and it looked as if they have what you need. If not then Grainger.com
Old 01-28-2014, 07:10 PM
C-FAH Q's Avatar
C-FAH Q C-FAH Q is offline
Default Need help with part number
I am also trying to find this tee. This is used in primer lines. Note the flared surface inside for the ball union to mate with. Anyone have a part number? McMaster Carr and grainger do not have this tee.
Gary Wilcox
St.Thomas, Ontario. CYQS
RV7 Sold
www.Facebook.com/Purplehillair
www.purplehillair.com
C-FAH Q now N281CT
gwilcox3 @ gmail.com
Old 01-29-2014, 06:18 AM
Try Tom Brink at GAHCO. Part number AN795-2.
Tom
Ridgeland, SC
Old 01-29-2014, 06:24 AM
mahlon_r mahlon_r is offline
I believe the Lycoming P/N is STD-853 for that T fitting.
Good luck,
Mahlon
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
Old 01-29-2014, 06:28 AM
C-FAH Q's Avatar
Thanks for the help
Gary Wilcox
RV7 Sold
C-FAH Q now N281CT
Old 01-29-2014, 08:10 AM
Tony Spicer Tony Spicer is offline
Aircraft Spruce has them. PN 01-00215, $74.75 each. Must be a Lycoming part. Makes 1/8 flared fittings look like the way to go.
Tony
