Old 12-03-2013, 05:39 PM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Thermocouple/firewall planning ?
I need to decide if miniature TC plugs at the firewall are reliable vs. hard wire through the firewall and disconnect EGT & CHT sensors for engine removal. Rainer ( MGL ) says copper extensions are acceptable as long as the cold junctions ( solder joints ) are the same temp. This makes a D-SUB connector at the firewall viable. Any comments ???........Larry
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 12-03-2013, 07:07 PM
aerhed aerhed is offline
I don't know how "approved" it is, but I ran all 12 thermocouples to one CPC male with a bulkhead connector on firewall. Gold pins and continued inside with the k-wire to the RDAC on sub panel. Temps were perfect and stable on an Odyssey.
Actual repeat offender.
Old 12-04-2013, 10:49 AM
Mich48041 Mich48041 is offline
True, but the fewer splices the better. 99 percent of electrical problems are poor connections. Keeping those connections and terminations to a minimum will lessen the chances of failures. A non-existent splice can not fail. The installer must weigh the convenience of having a splice against the risk of the splice causing future problems.
Joe Gores
Old 12-06-2013, 10:17 AM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
I agree with the above ! Never add a connector unless there is no way to do without. Both the egt and cht probes already have connections at the sensor, so from a serviceability standpoint, nothing is gained by a firewall connection.
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
