12-02-2013, 07:23 PM
Battery charging with cowl installed.
With an EFIS in the panel, I need to perform regular software upgrades, upload maps, plates etc. Keeping the battery charged when your only access to it is through the oil door is not ideal. I'm considering mounting a pad close to the oil door and connected to the plus side of the battery. It would need to be well insulated when not in use, but would make the process of charging the battery much more convenient. Has anyone done something similar with photos of their setup?
12-02-2013, 07:30 PM
If you buy a "Battery Tender", they come with an insulated plug you can attach to the battery or "hot" side of the master solenoid. Just keep it "twist tied" close to the oil door and you can use it when needed.
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
12-02-2013, 07:40 PM
I have a fuse protected "always hot" 12v outlet in the cockpit that I use to trickle charge at <2A when/if necessary.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
12-02-2013, 07:51 PM
I did this as well, both for use while working on the aircraft as well as for charging phones etc. in flight.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
12-02-2013, 08:12 PM
Yep, me too. makes it easy to plug in the "Tender"
12-03-2013, 08:32 AM
Tied to the oil filler neck
I also installed my tender plug inside the oil door by tie wrapping to the oil filler neck. That way the canopy stays closed.
Bill E.
RV-4/N76WE
8A7 / Advance NC
12-03-2013, 08:45 AM
Another one here with a 12v outlet (cigarette lighter socket) in the panel that goes straight to the battery thru a small fuse.
Neal Howard
Airplaneless once again...
12-03-2013, 08:54 AM
Battery charger plug
My battery is aft mounted complicating matters a bit. However I also have a reverse NACA duct for air outflow on the belly aft of the battery. At the time installed the charger wire all I had in stock was a 9pin Sub-D connector, so I used that, mounted inside the NACA duct. I attached the mating connector to the end of the battery maintainer cord. The nine pin plug allowed the connection to include the thermocouple wire, too. (My battery maintainer uses a thermocouple to prevent overheat of the battery.) When I have time for a do-over, I will use an AMP connector for a more secure connection.
Craig Taylor
RV8 flying
2020 VAF dues paid with thanks
Navy A7E Vietnam era
Ret. Corporate Pilot: G1159, IA Jet, Jetstar, Falcon 10, 20, 50
12-03-2013, 08:58 AM
I installed an "accessory plug" inside the oil filler door; adeled it to the engine mount x-bar. It's only about 10" from the battery, so the wiring to the terminals is very short. My Odyssey Optimizer plugs into it. I got the idea from Dave Burden's 9A.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
12-03-2013, 09:39 AM
Yep, Me too (or three or four)!
Bill
RV-7
Lord Kelvin:
