Old 09-05-2006, 09:25 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Default Round, three pin connector
I came across a decent deal (I think) on a turn coordinator, but it uses a connector I cannot find anywhere. The connector on the unit is threaded, round, three pin connector. I checked ACS and Wicks for the matching female connector but couldn't find one there. Anyone know what this might be?
Thanks!
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 09-05-2006, 09:33 PM
N375JS N375JS is offline
You may be able to find what you are looking for here
http://www.digikey.com/
I have found all unique style connectors at digikey, hope this helps
Old 09-05-2006, 09:46 PM
Rosie's Avatar
Rosie Rosie is offline
Location: I live in on the Rosamond Skypark (CA) and am married to Victoria (Tuppergal).
I believe you'll find what you are looking at Chief Aircraft on their turn coordinator page; AMP brand, 3-pin cannon plug, Rosie
Paul A. "Rosie" Rosales
Rosamond Skypark (L00), CA
RV-6A, 4200+ hours since 7/4/2000
Old 09-06-2006, 07:57 AM
ChiefPilot's Avatar
That's the one - thanks! For anyone else who might come across this in the future, the connector is a MS3106A-10SL-3S Cannon Plug made by AMP.
Thanks!
