Which Side Up?
One would think after 200 hours of build time, I would find myself not questioning my expanding builder knowledge, or lack of, as many times I do. Most of the time I can find my answer here, or looking at other build sites.
So with that said, after a extended building session is holiday weekend, and getting the right elevator of my -8 project ready to rivet the skin on. For the 12 470AD4-4 rivets that fastens the elevator horn, WD-605-R-1 to the Spar, E-702, does it really matter which side the head of the rivet goes on? Rivet head against the elevator horn or against the Spar?
What I did not state at first is that I already have it riveted together with the "shop" end on the Spar. So after searching the site I found my answer, it seems it is procedure to have the shop end on the side of the thickest material. So do I chance drilling 12 rivets out and turning them around? And when it comes time for the left side do I match the right side or set them the other way?
Reason: more explanations
