12-01-2013, 07:29 AM
Troubleshooting EGT Probe?
My #2 EGT quit (G3X system) after the last test run, it red X'ed on the engine page. I wiggled the wiring and and it showed an erroneous climbing temp compared to the other EGT's that were cooling after shutdown. O-360, prior to first flight about 6 test runs on engine.
-Wiring and connectors look good.
-I swapped the #2 wires to the #4 EGT and the #4 wires to the #2 EGT and the Red X was displayed on #4 cylinder.
I assume there is a way to test the EGT probe with my Ohm meter, but I'm not sure of the values.
Does anyone know what values I'm looking for?
Andy
RV 7 400 hours and counting
19 donation done
12-01-2013, 08:02 AM
An ohm meter will show a very low (< 1 ohm) resistance value of a good probe.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
12-01-2013, 08:25 AM
Thanks Walt, one more questions.
-No continuity would equal bad probe?
19 donation done
12-01-2013, 08:26 AM
That would be correct.
12-01-2013, 09:18 AM
I climbing temp when cooling is a sure sign of a thermocouple hooked up backwards.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
12-01-2013, 10:28 AM
It was hooked up and working correctly for the first 6 or so engine runs, the connectors were still hooked up and appeared secured after I removed the fiberglass sleeve and heatshrink.
Thanks for the reply,
Andy
19 donation done
12-01-2013, 07:35 PM
After making it out to the hanger with the Ohm meter and the #2 probe (bad probe):
-No continuity between the red/yellow leads
-No continuity between yellow lead and probe body
-Continuity between red lead and probe body
The properly functioning #4 probe showed continuity between both leads and between each lead and the body of the probe.
Will call/email for replacement tomorrow.
19 donation done
12-01-2013, 09:32 PM
Recommendation to all builders...Write down any information from every part you install in your build manual. Also do a little non-destructive testing on things so you will have some baseline readings to go by when you need to troubleshoot down the road. All EGT probes should have loop resistance and millivolt output readings noted. I heated my probes up in a dimly lit shop with a propane torch approx 3" away until they started to glow(1500-1600F), then noted readings.
http://alcorinc.com/wp-content/uploa...e-Rev-2011.pdf
Ask the manufacturer or someone with experience before testing a particular component, as you can cause damage.
Good judgment comes from experience, and a lot of that comes from bad judgment.
12-02-2013, 07:26 AM
Hello Andy,
Sounds like a bad probe to us too. We received your email and will get you a replacement.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
12-02-2013, 07:38 AM
Wow, Thanks!
19 donation done
