Showplanes FPS problem
This is on an RV-10 but I suspect the system is similar on other models.
My Showplanes Flap position system stopped working a while back. Flaps worked as if no positioner at all when under flight loads. A&P at last annual worked on it and worked until today.
Now when switched to retract it stops at the "half" flap position intermittently with no flight load. When I apply flight loads by hand as the FPS rod passes the "half flap" notch it retracts fully as normal.
Anybody have any experience with this?
Maxwell Duke
Kitfox S6/TD/IO240/SteamIFR Built it
RV10 IO540/AFS5600x3 Bought it
CH750 O200/AFS5500. Built it with 7 friends. DAR-Vic Syracuse
Maule M7-235C Sold it(kind of miss it)
VAF paid 5/2017
